Results 1 to 7 of 7
    May 2009
    Mukhang wala pa atang nagbebenta neto sa pinas.... napuntahan ko na mga major malls sa manila, etc. etc. halos yung steering wheel lock lang meron. kaso madaling putulin kasi ang steering wheel kesa pedals ng sasakyan.
    kaya sa tingin ko mas maigi na itong pedal jack o kaya clutch claw. kaso nga wala pako nakikitang shop na nagbebenta neto. o baka naman meron na at may nakakaalam sa inyo.
    saka ko na isunod yung alarm/immobilizer.
    Jun 2006
    How about a kill switch?
    Aug 2004
    Quote Originally Posted by Horsepower View Post
    Ditto. The "kill switch" is the easiest and best way to prevent theft. Hide it where no one can see it and where it can't be easily reached, and they can hotwire the car till kingdom come and it won't budge. Had it on my project car in the past.
    Sep 2013
    best place is just above one of the pedals, pag na carjack isang upward motion lang ng leg para matrigger ang kill switch (toggle switch works best).
    May nakita ako sa Top Gear Ph magazine na plug-type kill switch. It looks like a military plug, pero kapag tinanggal mo siya exposing the pins, hindi aandar ang kotse. Sa Laguna yata yung company na gumagawa.
    May 2009
    gagawin ko talaga yung kill switch/(es). tatagal naman siguro yung toggle switch na nabibili lang sa auto supply ano. para sa starter circuit (solenoid cut-off). pati na rin sa fuel cut solenoid.
    may nakita ako sa olx na kill switch (may susian) worth P500. from the looks of it e pang heavy gage wiring yun. ok naman kaya ito?
    May 2009
    konting update lang.....
    done the (starter) kill switch with a mini toggle switch. next ay yung injection pump.
    at ako'y nakapagfabricate na rin ng "anti-theft device" similar to the pedal jack. hinalungkat ko yung koleksyon ko ng bakal at ang ginamit ko e yung 2 x 3/16 inch angle iron at 2" x 8 mm thick flat bar.
    tapos bumili ng padlock na mahaba at may pedal jack nako. just below P500 lang siguro ang cost nung konting bakal, welding rod, kuryente at kandado.
    well, ang magnanakaw e talaga naman makukuha ang isang sasakyan kung talagang gugustuhin. itong ginawa ko e some sort of delaying tactics lang naman.
    pinakita ko sa pinsan ko yung finabricate ko na pedal jack e gusto rin nya magkaroon. kaya gagawa uli ako ng isa pa o dalawa. DIY lang. magandang exercise din para marejuvenate ang fabrication and welding skills.
Pedal Jack / Clutch Claw
