Results 1 to 15 of 15
    May 2005
    mga pare at mare, me problema po ko help naman po jan... kapag nilolock ko ung doors ng kotse using the remote, ung lock sa isang door(driver side) hndi naglolock... ok naman lahat, except that the driver side doorlock DOESNT LOCK! pano gagawin? TIA
    Jun 2005
    It happened to my car one month after it was installed. I returned it to the installer for repair. Then, after a month, the same thing happened again. Back to installer again. Then for the third time, then back to installer. It has been fixed and I'm hoping it would never happen again.
    Question:
    Wala bang available sa market na "selective" keyless entry / central lock. What I mean is you would also have the option to remotely lock/unlock any door. So, if you're the only occupant of the car you would only lock/unlock the driver's door.
    Ano po ride nyo? New unit under warranty or not? Kasi kung warranty pa yan pwede mong ibalik sa pinagbilhan.
    Kung hindi na, maluwag lang yung shaft sa loob na kinakapitan ng master control. Kelangan buksan ang sidings para higpitan. I'm sure gumagana pa yung master control nyan since you pointed out that other door locks still activate except for the driver side lock.
    Merong available na alarms wherein you can opt for unlocking the driver side door only or unlocking all doors in one press. Afaik, wala pang nilalabas na option for selective unlocking/locking any doors. Just forgot the brand while typing... it will cost more than your ordinary alarm.
    May 2005
    saan kaya pede ipaaus un.. uhm wla na waranti po ung car...
    May 2005
    Quote Originally Posted by j_avonni
    .. umm .. not sure of what the locks are for my '05 civic .. pero parang ganon siya gumana .. press once and yung driver door lang ang bubukas .. twice and lahat ng doors bukas ..
    Quote Originally Posted by gaby_bear03
    Try your luck in Banawe shops that fixes, any shop would do and charge you for the labor & parts. Just avoid the roaming Banawe boys which you will have no job warranty if all else fails.
    PS. Text character is not allowed in tsikot. Feel free to type in the whole words. We don't charge messages posted per characters. ;)
    May 2005
    hehe sorry bossing... nxt time =P
    Jan 2003
    what brand yung may selective keyless entry?
    May 2005
    saan po b mpagkakatiwalaang shop for keyless entry/alarm? help naman poh...
    You could try Jaffas Accessories' technicians, they know what to tinker when it comes to reprograming alarms. Beside Jetcar along Banawe inbetween Dapitan & M.Cuenco Sts.
    May 2005
    thnx, ill try to go there =)
    Sep 2005
    hello. naghahanap din ako ng keyless entry. pa post naman kung san kayo nakahanap at magkano.. ung parang kay mrpink.. press once and twice.. meron kaya? Thnx in adv. =)
    Quote Originally Posted by Ungas
    sir,yung exalta ko thrice ko na binalik sa jaffas,the right front door lock keeps burning out.sa kanila ko binili yung replacement,class a daw.around 2 weeks apart kung masira.1box (4pcs) motor na nga yung binili ko sa kanila coz P400 daw isa pero 1300 1 set theory nila baka daw di kaya ng japeyks na replacement nila yung wattage na bigay,alternative ko daw casa,probably P3k...any alternatives?
    Quote Originally Posted by miluku
    2-step unlock capable na keyless entry ang kilangan mo pre. tanong mo lang sa mga local stores kung meron sila.
    Quote Originally Posted by wulf
    di ba same door lang, baka may leak at nakakapasok ang tubig sa actuator kaya laging sunog. you might not need to shell out 3K just for that one actuator problem.
Keyless Entry Prob
