Results 1 to 13 of 13
    Mar 2005
    when will i know if my remote control's battery on my key less entry needs to change? Bale mag 3 years na rin ito since na nabili ko car ko last 2002.
  2. #2
    Mmm... if it has a weaker "signal" and di na one-click pag pinindot mo.
    Mar 2005
    Once press mo yung button ng RC. mahina lang yung sound ng alarm, so dapat thrice mo e try saka tutunog yung alaram nito signalling na open na yung door. nangyari ito 4x na sa akin.
  4. #4
    better change your battery... mura lang naman yan.
    Mar 2005
    Quote Originally Posted by BongersVX200
    Usually pag nag less na ang range kailangan palitan na. Like kung dati eh na activate mo siya 10ft from the car tapos after a while suddenly kailangan nakadikit ka na halos sa kanya para mag activate ang alarm palitan mo na.
    Feb 2005
    I agree with ILD: palitan mo na lang ang battery. Mura lang naman yun eh.
    Mar 2005
    what particular brand ng battery ang recommended ninyo? DIY lang ba ang pag palit ng battery? Thanks..
  8. #8
    DIY lang bro. Naka screw ba yan or clip? mabilis lang yan. Di ko kabisado mga brands.
    Mar 2005
    naka screw lang..what brand kaya?
    Feb 2005
    Any brand. Just as long as it has the same voltage. Kahit aning brand yan, basta made-drain, made-drain. Okay, if you want to be specific...hmmmm....let's see......there's Maxell, Panasonic, Sanyo, Sony, Duracell, and a bunch more. If you ask me, go Maxell. Pero, AFAIK the brand does not make the difference. H'wag ka lang bibili nung tig-P 10 na nabibili sa bangketa.
    Around 35 pesos lang ang isang battery.
    Feb 2005
    o di kaya use your duplicate RC key..you should have at least one when you bought the unit..
    Feb 2005
    speaking of rc, possible ba na palitan yung rc ng mas maliit sa original remote but with the same controls?
key less entry remote control..
