Results 1 to 3 of 3
    Jul 2011
    Good day po, first time post ko po ito.
    baka po meron sa inyong may alam ng wiring diagram nitong A-Power keyless/security module na to.
    main concern ko lang po ehh mapagana un keyless kahit po hindi na yung sa security alarams at sa mga lights kpag pinipindut yun remote
    (working naman po un remote at nag tick naman circuit relay kapag nilalagyan ko ng power un ibang pins)
    additional info : presemtly meron pong working cental lock module w/o keyless support, at napag aralan ko na po un module kaya familiar na po ako sa wiring at color coding nito
    option1: remove the present central lock w/o keyless tapos transfer A-power module para central lock withe keyless entry in one ( di ko na kakabit un security alarm nya)
    option2: wag ng alisin un present central lock w/o keyless tapos hanapin un signal out nun A-power para sa brown at white wire para ma i-connect sa signal input nun central lock w/o keyless , inshort present central lock w/o keylesswill control the enitire door lock system and the A-power will only be used for remote control
    mas ok po sana kun ung option1, pero any input will be very much appreciated. Thanks in advance mga masters
    Jul 2011
    sana po may mapadaan na familiar dito. tnx tnx
    Jul 2011
    waiting for any response, sana po meron mapadaan n nakakaalam bago ko masira un module kakatrace ng wiring nya, hehehe
HELP! "A-Power" keyless/ security system wiring diagram
