Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Jan 2013
    Keyless entry for cars are becoming a norm these days.
    I'm just curious, what happens if you have your key inside your pocket and you leave the car while the engine is running? Will the engine stop or will it continue to run?
    Maybe different cars will have different behaviors.
    Sent from my ONEPLUS A3000 using Tapatalk
    Jul 2016
    Quote Originally Posted by remzam View Post
    Gano ka kalayo sa oto? If pumasok ka lang sa loob ng bahay nyo nilapag mo susi sa sala nyo or kwarto wherin within range pa ng key sensor. Di mamamatay. Or mamatay lang pag wala ng gas.. LOL. Pero again, depends pa rin sa manufacturer.
    Jun 2015
    Engine keeps running. Alarm system won't let you lock the doors from outside. There's only an alarm to let you know the key is out of range.
    Actually, someone can just hop in and drive the car away if you leave it like that. Once the thief shuts off the engine, however, there's no way to start it up without the key (immobilizer and all that).
    Key fobs usually have a VERY short range. You'd have to be standing almost in front of the door's lock button for you to unlock/lock the door. That means no one can sneak up and unlock the doors behind your back as you are walking away. The car can also tell if the key fob is inside or outside the vehicle so you can't turn on the engine even if the key fob is close by but not inside the cabin.
    I'd suggest you try to download the owner's manual of the particular vehicle that you're interested in.
    Tapatalked
    I think this should be "cars with auto start" or something and not "cars with keyless entry"?
    _/_/_/
    31.7K _/_/_/_/_/_/_/_/_/_/
    Jan 2013
    _/_/_/
    Onga. Mods please change Title. Kasi nga naman keyless na nga pala yung remote open and lock doors.
    Sep 2005
    for the new ones, if they drive off without the key, it will stop after a few meters diba?
    Tapatalked
    Jun 2015
    Perhaps the more expensive ones. I'm just relating how mine behaves from experience. There have been times when my wife carries the keys in her bag and forgets to hand it over to me as she alights to open our garage gate. I haven't tried driving far without the key but there's nothing in my owner's manual that indicates the engine will shut itself down.
    I also doubt that cars will be designed to shut down when it loses contact with the key fob transmitter. What if the key fob battery runs out while you're cruising on the highway? That'd be potentially disastrous.
    Tapatalked
    Jul 2016
    Tapatalked
    Forgot that running out of battery and ruiningbyour long weekend vacation or highway experience.
    A more serious problem is carbon monoxide poisoning. There were reported deaths already linked to keyless entry nakakalimutan patayin engine as OP stated .
    Keyless entry vehicles linked to deaths - YouTube
    Jun 2012
    Quote Originally Posted by Janemar View Post
    Ilang beses ko nang na-experience yan. Iniiwanan ko kasi ang key sa loob.
    Jul 2016
    Quote Originally Posted by confused shoes View Post
    Mukhang malabo naman ito mangyare sa atin since wala naman masyado naka heated/enclosed garage sa pinas. Either open garage tayo or sa kalsada lang naka park oto. LOL.
    Sayang lang din gas at kawawa makina mag carbon build up if naiwan naka idle ng matagal...
    Sep 2016
    Hindi na ako nakapag-read back ng mga replies pero curious lang ako with regards to vehicles with keyless entry system.
    SAFE BA TALAGA ITO PARA SA SECURITY MO HINDI LANG NG MGA GAMIT MO SA LOOB?
    Scenario:
    Nasa loob ka ng sasakyan mo na keyless entry. Engine off, key fob inside, may dala kang valuables, and door's locked dahil pinindot mo yung central locking switch sa loob ng vehicle. And then out of nowhere, meron dumating na mga holdapers. Given the situation above, kahit naka-lock na yung mga pinto mo but the key fob is inside the vehicle, pag pinindot ba nila yung "unlock" button sa door handle, magbubukas pa din?
    Correct my curiosity if i'm wrong because I have never driven a keyless/push start-stop vehicle ever since pero kung totoo nga na meron malaking compromise sa security sa mga keyless entry eh ewan ko nalang bakit pinapauso nila yung ganung technology.
    By the way, I've brought this up because I'm thinking of getting the 2017 Isuzu Dmax 4x4 --- but it's keyless and push start-stop already, unlike the Hilux Revo and even the top-spec Everest Titanium, traditional key ignition pa din.
    Mar 2004
    Quote Originally Posted by Offroad_Goals View Post
    The door can't be unlocked from outside if the key fob is inside the vehicle ... but does it really make a difference if there's only a piece of glass in between a gun and your head?
    Jun 2012
    Can be unlocked using the door combination lock. On some models.
    Sep 2016
    Thank you for the input sir! Will definitely try a keyless entry vehicle and just see for myself. Btw sir, yes it does po especially if the windows are bulletproofed, but then again if it won't unlock if the key fob is inside than that's a good feature.
    But just a random thought again, will it be impossible for to jump start a manual transmission vehicle with a push start/stop system?
    May 2017
    I think it will stop. Because I didn't seen any car is running without a key.
    Jun 2012
    Oct 2009
    sa ford diretso parin ang andar.kahit san ka makarating wag na wag mo lang papatayin makina saka .diretro parin ung alarm na.ung susi daw ay wala sa kotse
    Sep 2005
    mas madali daw nakawin yang may push start, all they need is a blank key fob, an obd scanner and they can re-program a new code sa blank key fob.. is this also happening here sa atin?
    Jul 2016
    Yes, kita ko nga sa youtube. Mukhang madali lang gawin especially if you have the right tools or if may background sa electical.. Mostly the cloning kits are from taiwan and china.
    Kahit nga cguro wala ka background sa electronics, kasi nga mga ATM at Credit cards na cloclone ng kung sino sinong sindikato lang... Only time will tell pag dumating na sa bansa technology...
    Jun 2015
    Probably wala pa rito. Even yung mga nag-o-offer ng key duplication service hindi pa kaya.
    Tapatalked
Cars with Keyless Entry
