Results 1 to 6 of 6
- Sep 2007
- 56
December 2nd, 2007 12:40 PM #1Hi guys,
I need help. Yesterday, when i was about to go home, my alarm went off (this is still when I was outside the car) after i pressed the disable button para iopen ko ung doors. when i tried to stop it by pressing the disable button again wala parin. sobrang ingay. halos lahat na ginawa ko. labas ulit, then close yung doors tapos press ulit ung disable button. ganun pa rin
then i decided to disconnect the battery muna para hindi makabulahaw (that was around 12:30 am nga pala). then i called someone to look into it. inalis nya ung buong aparato sa ilalim ng manibela pero tumutunog pa rin kapag kinakabit ung batterya. inalis namin ung relay ng horn muna para hindi maingay pero ung alarm tuloy tuloy pa rin. hindi ko tuloy mastart ung sasakyan. then halos lahat na ng tao naglabasan ng bahay at nanonood. tapos meron siyang inalis na relay sa ilalim ulit ng manibela at ayun nadisable na un alarm. guys ano kya ang cause nun? naalala ko ok naman siya kahapon bago ko ipalinis ung engine (pinahiran lang). alarm ko nga pala is predator. thanks for the input
December 2nd, 2007 08:15 PM #2
sir, try mo din i check yung mismong remote mo, minsan nagloloko na yung button, worn out na yung spring kaya maski hinde mo pinipindot nag oon or nag ooff. ganito kasi experience ko dati, nag aactivate tapos de activate tapos minsan nag aalarm mismo. tapos ko ayusin yung trigger button niya ok na.
- Sep 2007
- 56
December 2nd, 2007 08:54 PM #3sir,
actually oks naman po ung remote kasi nung kinalas po ung relay sa ilalim ng wheel para ioff ung alarm e oks naman ang remote. saka kakabili ko lang po nung alarm ko mismo wala pang 1 month. ngayon tanggal pa rin ung relay at hindi gumagana ung alarm
- Nov 2007
- 7
December 3rd, 2007 05:35 PM #4medyo related problem. nakadisable na alarm. pero di na din gumagana keyless/remote nag-stuck up na. ok lang sa kin ala alarm. meron ba nagrereplace or repair nung remote lang. adventure SS 2001 pala sasakyan ko. nakalimutan ko brand ng alarm. yung original pa yun pre-installed.
thanks!
- Feb 2007
- 89
December 5th, 2007 09:46 AM #5Mag valet mode ka muna to stop it from arming then bring your car to the alarm installer, mas alam nila ang dapat gawin :-)
December 5th, 2007 10:56 AM #6
ganyan dati yung alarm ko. predator ba? ang ginawa nmin inalis nmin yung relay niya para mapatakbo at ipinunta namin kinabukasan sa nag-install. ganun din po sakin halos isang buwan lang nagkaganun na...naasar ang dad ko pinapalitan niya at dagdag nalang siya...pinili ko ang autopage RF315..dahil sa tsikot.com nalaman ko tong alarm na ito..ok ito...kung ako sayo sir papalitan mo nalang at dagdag ka nalang sabihin mo lagi ganun nangyayari...mahirap yan pag nag out of town ka tapos nagloko...
just my 2 cents...hehehe
Daming issue ng SU7:grin:
Xiaomi E-Car
