Page 17 of 27 FirstFirst ... 7131415161718192021 ... LastLast
Results 321 to 340 of 951
    Quote Originally Posted by kompressor View Post
    Was able to source a Beret car alarm that has retractable keyfobs with remotes integrated in it. Cost me 1.5k from a seller in another online classified site.
    Keyfobs look like these below. The one I got was the switchblade type as it was the only one available for Nissan blank keys. Might get another for my brother's Altis as the second one looks like Toyota's OEM key (and it's for a Toyota).
    Installed it DIY and the alarm module allowed me to wire it to activate the signal lights without the need of a diode or additional accessory.
    Good day po. Ask ko lang ano effect kapag mag-open ka ng door? mag-flash po ba lights na parang naka-hazard lights?
    Ano effect po kung naka-on ang turn/hazard lights at makapag-open ka ng door sabay ilaw ng lights galing sa alarm?
    Quote Originally Posted by rodetor View Post
    Usually ganun. Twice na iilaw. Kapg nag-lock naman, once lang yung sa akin mag-flash.
    Feb 2011
    Ano ba talaga dapat ang iilaw pag bukas mo ng pinto? Parklight or hazzard? Best practic. DAW is hazard para safe pag bukas ng pinto..
    Paghimayin yung alarm wiring, dalawa line ng "door ajar" light. It's made for left and right signal light... Pwede naman kasi tap yun kahit saan, kahit brake light. Standard practice lang yung sa signal light.
    Jan 2014
    Mga Sir,
    Anong Alarm ang OK ngayon? I have a 2005 Honda Civic.
    OK na ba yung Viking or should I go for AutoPage?
    Ano po ba advantage ng AutoPage over Viking?
    TIA.
    Quote Originally Posted by johnpaul0801 View Post
    Ask lang po ako newbie here... Ano kayang pedeng alarm ung pedeng ikabit sa mga push button car na lHat ng functionality ng car alarm mag wwork like engine cut off?
    Quote Originally Posted by afv1012 View Post
    Mga Sir,
    TIA.
    I always use autopage for aftermarket alarms once I want to change the stock security system. I currently have these installed in 3 vehicles and will most likely have a 4th one installed soon. The one installed in the sedan also has a function to open the trunk so I can open it remotely such as when I'm carrying grocery items. It also has a remote start that comes on a separate key fob. I rarely use it though since I usually forget that it's there.
    Quote Originally Posted by K.I.L.L. View Post
    May I ask where you sourced your Autopage, as well as around how much it costs?
    Thanks!
    Sep 2010
    Sirs, you can try this link for the Autopage car alarm autopage car alarm for sale Philippines - brand new and 2nd hand. I think Roadstar also has this in their stock asdie from Code Alarm which is also good. Had this installed in my 2013 Santa Fe.
    Incidentally, any one here knows which shop specializes in installing a Viper Car Alarm? I have this Viper car alarm model 5904V which I bought from the US but am having a hard time trying to find a reliable installer. If you know one, please let me know, a contact number will also be of much help! TIA
    Thanks!
    C3 4x4. I remember I paid 4,000+ for the standard variety and around 6,500+ for the one with the remote start.
    Quote Originally Posted by [archie] View Post
    Sir newbie po ako sa car alarm. Ask ko lang, kung dalwa line wire ng door ajar light ng car alarm at naka tap sa left and right signal lights. Paano po kung naka hazard ka at umilaw po un sa car alarm sa pag open ng doors, hindi po ba masira ang flasher relay or masunog ang signal light wires ng sasakyan?
    Hi to all tsikot members. Patulong naman po. Ask ko lang kung pwede i-tap direkta sa turn/hazard light mula sa alarm? Dalawa po ang lights wire mula sa alarm. Hesistant lang ako ikabit sa turn/hazard light baka magkaroon problem sa turn/hazard light relay ng sasakyan. Viking car alarm ang gamit ko.
    *kill, what model of autopage has the remote start? And how much is it?
    It's the C3-RS-665. The separate key fob is the C3-RS-665 2W. Installing it took a while though and because of the remote trunk opener, I can't lock my trunk anymore since if I do, the remote mechanism gets disaligned. So long as I don't lock it, it works flawlessly. The remote start works in the same way as those push start / stop buttons except it's outside the car. There's also a provision if you want to attach a remote window opener to roll down your front windows remotely but I never bothered with that.
    Apr 2010
    Does this remote start function has a fail-safe mechanism to avoid starting if not in N or P? And probably an option to turn AC remotely?
    Oct 2013
    Quote Originally Posted by ezrydre View Post
    remote stat will not work if not in neutral or park for A/T and parking brakes not engaged for MT (remote start not recommended for MT)
    Apr 2010
    Thanks Stigg for the reply. Looks like it's not really recommended for MT. Because you can still crank the car even if in gear.
    Viking Car Alarm. Maganda rin ang alarm na ito. Mag 1 year na sa april mula pa maikabit ko ito wala pa rin problema. I bought it from Mr. Roman Lao with central locks. And much more affordable for a basic car alarm from other brands. Lalo na if you are not a branded conscious person. Ok talaga.
    Mga sir help naman..bago lang ung car alarm ko mga 50days pa lang sya..pero kanina po e hindi nag wowork ung unlock nya dapat sususian pa..pero pag ilalock naman e nagwowork pag lock..anu po kaya problema dito? Salamat
    Quote Originally Posted by rdz03 View Post
    Best thing to do is to return to the shop where you had it installed... Under warranty pa yan dapat
    hi mga sirs. new car owner and I want to improve my car's security.
    basic toyota alarm lang kasi, gusto ko yung may mga autolock and yung tumutunog bag nasagi. hindi ba mavo-void ang warranty ng car (like electricals and wiring) due to aftermarket car alarms mentioned in this thread?
    TIA.
car alarm: anong maganda ngayon?
