Results 1 to 11 of 11
    Got this problem of always leaving my key at the ignition switch and my car will lock itself due to the autolock feature of the car security system.
    How to remove this feature??
    Quote Originally Posted by mahandas View Post
    check the manual.
    Jun 2006
    keep a spare key in your wallet...
    Sep 2004
    Or carry a spare keycard in your wallet.
    EDIT: Crap, chuaed beat me to it.
    Ganito na lang. Pay someone you know to stay inside the car while you're parked. :D
    Aug 2005
    Quote Originally Posted by Bogeyman View Post
    Have a window slightly open para maabot ang lock sa loob.
    I wouldn't really recommend this, at least from my point of view . A 1/4 inch gap at the windows can easily invite a Slim Jim or T-Wire tool used for opening cars. If you do have to leave a small gap while parked just make sure that your car is very near the security outpost.
    Instructions/commands are always found in the package that came with the system. If you lost it then go to a shop that sells the unit/system then ask if you could photocopy the manual. I used to have this habit but I broke it after some simple practice of double checking.
    Jun 2006
    set your system to valet mode... sigurado hindi na siya mag autolock...
    iyun lang disarmed ang alarm...
    Ganito na lang. Pay someone you know to stay inside the car while you're parked. :D[/quote]
    haha.natawa ako dun
    Sep 2004
    check the manual.
    best answer.... ako nga.. na weirdohan ako sa alarm ko..after 1 minute, mag auto arm ang alarm, but the lock doesnt lock...i thought at first to change the programming..but after awhile..i said nah...its best that way..at least if i forget to arm it myself.the car will arm itself but not lock the door. if i wanted to lock and arm it, i just press my remote..at least meron guardian angel mag arm ng alarm but i wont worry locking my keys in.
    Sep 2004
    Minsan naman nangyari sa akin, parang nagloloko yung alarm ko when I tried to arm it. Tunog nang tunog, so I had to put it in valet mode para manual locking na lang, pero hindi ko pa rin maiwan.
    Tapos napansin ko, nakaparada pala ako sa slot ni Korina Sanchez. So that's why my alarm was acting weird, parang may bad vibes. Nung lumipat ako ng parking space, ayos na ulit yung alarm. :bwahaha:
    Jul 2006
    As far as I know an extra key will not help if the car is running and if you want to open the door with the extra key. Happened to us already - 1995 Corolla running. Left key in ignition, closed door and it locked. It was at home so we got spare key - no luck. Not even with the key on the lock to open it. We had to slim jim it open.
    Why would you ever leave the key in the ignition if you know it locks when you close the door? Thank God our MB's can never be locked with the front doors if they're open. I can manually override this by opening the rear door and closing the front door then locking it from inside and closing the rear doors.
    Just always make a mental note to open the window if you're going to open the door with the key in the ignition. Trust me, that open window will be manna from heaven if the door locks and you have no spare key.
Autolock features of car security system
