Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    For my Innova 2008 and Fortuner 2016....
    Scangauge II....Scanner + Gauges.
    https://www.amazon.com/ScanGauge-Aut...=fsclp_pl_dp_1
    Jan 2009
    I have both ScanGauge II and UltraGauge. Both should work on the ‘16 Fortuner.
    However, neither will work on the 1st Gen Innova. For your Innova, you’ll need Techstream, which is a PC-based software + physical dongle.
    bro ito ba yun may software na pwede mo delete yun ibang sensor?
    Jan 2009
    Not 100% sure but there are a few other things you can do from the software like initiating tests as well as capture realtime logging. But I haven’t explored this much for fear that I might do something that end up breaking something. Haven’t found time to go through all the literature so for now, I’ve only been able to use it to check and clear CEL and view engine parameters like coolant temp, fuel rail pressure, EGR position, gear position, engine speed, current speed, among many, many others.
    Dito ko nalaman before na may historical CEL yung Innova ko out of the factory.... Speed sensor disconnected.
    Apparently, they disconnect the speed sensor of brand new cars while still in the factory or maybe prior to delivery to the dealer so it doesn’t rack up any mileage on the odometer. Buking. Hehe.
    Jun 2005
    Pinapalipad nila mga yan sa expressway. Usually early morning. Ang bibilis pinatatakbo. Pag malas, overloaded pa ng parts na dedeliver sa casa
    Pagdating sa dealership, dun nila ibabalik odometer and fix a few dings and scrapes.
    Sent from my MI MAX 2 using Tapatalk
    Sep 2016
    It's what the casa people call "hugot". Had a first-hand experience of it during my OJT times.
    Feb 2003
    Quote Originally Posted by sirkosero View Post
    That was before..but lately I haven't seen a convoy of this BNEW cars going northbound in STAR...They are all now doing it via the car hauler/trailer. Ang Notorious dati is Hyundai vehicle...as in convoy in high speed pa..Mag 2yeara na ako wlang nakikita ganyan...BNEW cars travelling lang is yun mga new ISUZU / Hino Truck head...siempre ND pede i hauler yun.
    Quote Originally Posted by Jiggs View Post
    Ganyan pa rin ang Hyundai at Mitsubishi kawawang sasakyan lalo na sa mga bundok
    Sep 2016
    Nung nagbyahe kami pa-Mindanao, may 3 bnew Elantra kami nakasabay sa Matnog Port. Pagdaong namin sa San Isidro, harurot silang convoy.
    Feb 2003
    Ahh goin' to other dealership...pero from Batangas n Bauan Port mostly car carrier na even the Mitsu and Hyundai
    please update the thread if you have time bro [emoji28]
    medyo "pricey" na kasi sa kuripot na tulad ko [emoji38]
    may similar device + obd / usb yun tech ng suki ko, pero medyo madamot sa info hehehe
    siguro dahil alam nya ill give it for free sa friends once magets ko kung pano gamitin [emoji28]
    Yes such a feature exists but only on hi end cars. Tesla is one.
    You can have a part of the feature your looking for with a dual lens dash cam and the motion detection turned on. But it needs to be hardwired to the fuse box. Though it won’t notify you if your car got hit. At least you have evidence.
    Aug 2019
    ok lang ba na naka kabit lagi ang obd 2 sa obd port. pansin ko kasi naka ilaw ang red led light sa obd 2 kahit naka off na ang car. di ba drain sa batery
    Quote Originally Posted by wenz_vios 1.3 x View Post
    What OBDtool do you have? Scangauge2 sleep mode is triggered by either voltage or transmission sig, whichever applicable.
    Aug 2019
    elm327 obd2. naka kabit sa obd port. na testing ko na gumagana naman torque pro app ang gamit ko
    Not all ELM versions have sleep mode.
    Aug 2019
    so meaning cannot always put the obd 2 in the port
    yung ELM327 ko sa car di ko na tinatanggal sa obd2 port, walang battery drain kahit several days di magamit ang car
    measured battery current 20-30 mA pa rin, normal lang
    Jun 2005
    Quote Originally Posted by kinyo View Post
    More than 5 years na nakakabit sa obd port ng vios ko yung elm327. Wala naman naging problema
OBD2, what brand, where to buy and how much?
