Results 51 to 60 of 116
June 16th, 2010 08:32 AM #51
This version, I understand, is a recent release. There are a lot of places of interests that were added here.
It is still best to rely on local knowledge when navigating and ask locals if the GPS fails you, in fact even when the GPS seem to work just fine. You'll just never know what lies in the roads ahead. But in your case, you have indicated that you've done that and still you ended up in an almost disastrous situation, so I guess it was a combination of map inadequacy, bad judgment and bad luck.
10.1K:mop:
- Apr 2009
- 401
June 16th, 2010 06:34 PM #52Yes, but afaik, it is still an old contributor's map, released August last year. So there are many changes that occurred since then. Here's how the roadguide updating works. All updates are incorporated in the contributor's version of the map. As I've said before, your correction will probably end up in the contributor's version and not in the free version. They do not update the free map like the contributor's map. What they do is when they feel that the free map is too old and obsolete for public use, they upgrade it to another version but it still will be an old contributor's version. The free map now is ver 1.07 while the latest contributor's map is ver 1.13e.
So my bet is that the free map will stay as is and the changes you'll tell them will be incorporated in the contributor's map. So unless I'm wrong in my assumptions, unless you become a contributor, you and other people who use the free map cannot enjoy those changes, up until RG decides to upgrade the free map again probably in another year or two.
- Jul 2010
- 5
September 29th, 2010 06:24 PM #54
lurker here. my first time to join in. not sure if this is way out of the topic. anyway, found this gps thing will be useful though i have a confusion. which is better the free downloadable map or the licensed map? and why? thanks!
October 1st, 2010 09:31 PM #55
or which is the most accurate... the downloadable or the licensed map?
October 1st, 2010 09:47 PM #56
Gamit ko sa garmin 255w ko yung Free maps sa roadguide.ph. Spoken street names na din
- Jul 2010
- 570
October 3rd, 2010 10:44 PM #57I've installed NaviComputer GPS Software in my Omnia2. It comes with Luzon map only. I use it to drive in Makati at kita naman yun mga pangalan ng building. Ang problem ay yun car marker is not accurate. Nasa kabilang kalsada at nag counterflow.
. But it still okay. Because its free software naman.
Tsikot Member Rank 4
- 2,719
July 5th, 2011 01:47 PM #58
July 7th, 2011 01:37 AM #59
November 14th, 2011 10:41 PM #60
Pwede ba ang OSM Philippine Map sa Garmin Nuvi 1360? Kailangan pa ba install ang MapSource? or I just have to copy the gmapsupp.img file? TIA.
Tentative price increase from removal of the pickup tax exemption leaked:
Toyota Hilux (9th Gen)
