CZintrclr::: I have changed my van's bulbs into PIAA brand. Ok lang din naman, no rewiring or relays added. Since it's still consuming same rate as the stock bulbs.
ok thanks. at least sure na pwde di mag pa wiring.
alam mo rin ba kung saan ok mag palinis ng headlight kasi one side ko madumi na. saka mag kano aabutin?
CZintrclr::: Dipende sa housing, merong headlight types na pwedeng baklasin yung cover, old schoolers like Toyota and Newer Honda headlights alam ko pwede linisin. Yung sa van namin sealed type lenses, pag binuksan may tendency magka moist ang loob. Kung sealed type yung sa Pajeros, you have no other option but to buy another set of lenses. Just like what I did to my Safari, sealed type na maitim na ang loob, nagpalit ako ng new lenses.
ssaloon pwde malaman saan shop yan?
may natanong kasi ako 1200 daw pero di ko alam ano brand ng relay
sa ACME Autoworks ako nagpakabit. nasa recommended shops na thread yung contact #'s![]()
usually 60/55 stock wattage ng lahat eh... correct me if i'm wrong nalang![]()
hindi ba masama kung 90/100 ang nakalagay na bulbs pero hindi naman na relay?
ako more than 3 yrs na nagupgrade ng wattage ng headlight , hinde ako nag relay or upgrade ng wiring so far ok pa naman... I recently bougt a Philips bulb, rainbow yun color if you look sa headlight mismo, niya but more on yellow scolor ang output, bale P350 * and bili ko, I just don't know the exact name nung model nag bulb eh,
Be sure to read the labels correctly. Merong bulbs na nakasulat light output same as 90/100. Pero ang actual wattage nya ay 55/60 lang. Ang kailangan kabitan ng relays yung real 90/100 output. Karamihan ng nakikita ko ngayon sa Banawe shops puro 55/60w with 90/100w light output.Originally Posted by jeff
Warren Automotive at Benavides St. near corner C.M. Recto Ave., in Binondo.Originally Posted by geode
