Results 1 to 4 of 4
    Jan 2003
    Suddenly kanina lang umaga upon using my right-left signal lights naging mabilis na yung pag-blink nya. Normally kasi 1/2 sec. yung blinking nya, ngayon na doble ang bilis.
    I checked with my manual, it says there if this happen; 2 may cause it: 1 is busted light and 2nd connection.
    My ride is Pizza98 1.3PS. Any input thanks....Clone
    Did you step outside to see if indeed there is a busted bulb?
    90% of the time, its just a busted bulb or a loose wire.
    Mar 2003
    try to check lang po kung may punde/busted na ilaw... sa harap and likod po. Otherwise, loose wiring yan Sir clone1537.
    nangyari na po din yan sa akin...
    Pag busted bulb kahit DIY lang pwede na para tipid hehehe (bili ka lang ilaw)!!! pero pag-wiring na, better seek prfessional help. Call a doctor, este, an electrician para sigurado!!! mahirap na baka masunog auto mo Sir...
    my 2 cents...
    Jan 2003
    Thanks boss Otep & Jaz333!!
Turning Left or Right Signal Lights Trouble
