Results 11 to 20 of 33
January 24th, 2012 04:54 PM #11
I have a similar question. Is it true you cannot use your HID lights as 'Pass Beam' meaning even during daytime when you need to signal someone instead of the horn.
January 24th, 2012 06:31 PM #12
Meaning you cannot flash them? Yes. You cannot. It will shorten its life span.
January 24th, 2012 08:55 PM #13
- Dec 2002
- 2,335
January 25th, 2012 12:13 AM #14when you flick your Hi column switch during the morning, you want to pass or alert some motorists of your presence. HID bulbs need a little more time than vs. halogen bulbs to reach the max lumens output so in this case, pde ba gamitin? pde naman but halogen bulbs will do a better job at it.
Another thing, turning ON and then OFF your hid bulbs frequently will shorten its service lifetime.
January 25th, 2012 01:42 PM #15
hi Sir Gary, if that's the case, let's take my ride for example, i own a 2009 Honda City, if I were to go ahead and get a projector retrofit (that includes hi-lo), so I am better off not using it as pass-beam and rely on the horn instead? Or does the projector retrofit come with a non-HID hi beam?
- Dec 2002
- 2,335
January 25th, 2012 02:00 PM #16I have a 2009 Jazz (GE body) and we basically have the same stock lighting system.
When I say it will shorten the lifespan of the bulbs, what I mean is if flash your Hi beam like crazy. If you do it 2-3x/day then it is not a problem. The OEM bulbs are even more sturdy and will not be affected by this so much. Have my Philips for more than 2 years already and I am using it like a standard halogen lighting system but of course the output is miles apart. I rarely flash though or use my horn, I use my brakes instead
For single bulb setup like the City or Jazz, we don't have a halogen bulb for passing. Sa Civic pwede yan or Altis na meron separate LO and Hi bulb.
If the retrofit is properly made, it's just like using a stock lighting syst with 3x more intensity
- Jun 2010
- 87
September 27th, 2012 10:19 AM #17
- Jun 2010
- 87
September 27th, 2012 10:25 AM #18what about for XUV crosswind running on single bulb,both HI and LO in one bulb(stock halogen)..is it possible to retrofit only the LO beam for HID and retain HI beam for halogen?
- Oct 2012
- 6
October 15th, 2012 02:18 AM #19hello po sa lahat! bago ko lang nalaman na mali pala yung pag ugrade ko to hid kit since i need a projector headlight pala. I have a hilux 2009. Magagamit ko pa ba yung hid kit ko na nabili if projector headlight nalng ang bilihin ko? or mas better if pa retrofit nalang? thanks po sa inyong tulong.
- Jul 2008
- 485
October 15th, 2012 10:00 AM #20sir mjdg, iba ang HID bulbs ng projectors (bolt on) sa HID kits pang halogen housing so hindi mo magagamit yan HID mo nabili sa projectors. And ang projectors normally comes complete with bulbs na pagbili mo. As to retrofit, the best pa din ang retro fit pero pricey talaga. No less than 20k for a good pair vs 6k-8k na bolt on projectors.
dapat palitan mo na yang HID on halogen reflectors mo dahil nakaka silaw sa kasalubong mo yang ganyan set up. if you can afford the retrofit, i suggest you go for it. if bihira ka lang naman mag drive sa gabi, then go for the bolt on projectors (55 watts) which is affordable and yet a vast improvement from halogens/hid.
yung xtrail ko, i installed bolt on projectors with 55 watts and happy ako sa buga. although i can still tinker with the cutoff to increase the hot spot. sa santa fe ko naman, since naka oem projectors na low beam, nagpalit na lang ako ng HID bulbs and happy din ako sa buga. both are hindi nakakasilaw sa kasalubong pero malakas ang buga sa kalye.
Suzuki JIMNY [merged threads]
