Results 1 to 20 of 40
    Jul 2006
    mga sir
    ask ko lang kung pwede ko palitan yung stock headlights ko
    AE101 Corolla 1997 Big Body.
    Specs ng stock: 12V - 55W
    gusto ko sana palitan ng: Higher Wattage Headlights yung
    nabibili sa mga malls na Lightbulb yung tig P400 pair yung 300Watts ata un
    pwede kaya? any modifications or salpak na lang?
    ty po
    Quote Originally Posted by sirmykel View Post
    mga sir
    ty po
    you don't change the actual assembly per se.
    ang gagawin dyan is i-uupgrade yung wiring, and lalagyan ng higher relay tsaka papalitan ng ceramic sockets to withstand the higher temperature ng bulb.
    Jul 2006
    sir di ba kaya ng bulb lang papalitan ko?
    wala akong babaguhin sa assembly yung bulb lang talaga
    300W? tunaw ang lens cover mo niyan for sure...
    and masakit yan sa mata for incoming drivers on the opposite side of the road. please give due consideration to other road users. 55/60W is more than adequate unless you are sporting super dark tints in your front windshield.
    Aug 2004
    100W pa lang minsan tunaw na ang sockets or worse sunog ang switch.
    Feb 2006
    ask ko na rin sir, di ba may 55/60 watts pero 90/100 watts daw. pwede kaya yun at di na ba kailangang mag upgrade ng wiring??? tnx
    Aug 2004
    Quote Originally Posted by evs_13 View Post
    Emphasis on the DAW. Usually may tint lang ang bumbilya para magmukhang puti. Lalong nababawasan ang light on the road. Mahal pa naman. Stick to stock
    maximum of 80/100W lang safe isalpak sa stock wiring and socket.
    i suggest mag Osram Silverstar ka, stock wattage but throws more
    than ordinary H4. you can also do a search, re headlights upgrade
    for more options/suggestions.
    hindi yan kaya ng stock sockets tsaka ng stock wiring.
Stock Headlights replacment
