Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Oct 2003
    Does anyone here use HID lamps for their headlites?
    Appreciate your comments.
    for those who use it... who also use wrap around heavy tints... is there a performance hit when using heavy tints? (meaning is it better than using normal headlights with heavy tints... or not?)
    Oct 2003
    I think it's defenitely better than stock halogen lamps.
    I fitted a Philips Hylow 6000K kit with full tint on the windshield.
    City driving, xenon gas discharged bulbs simply outperformed the halogens. From my own driving view, the light clearly lits the road. Just don't expect the bright to function same as halogens. Gas discharged bulbs needs more intensity for long range and it simply lits up the upper part of the horizon. But provides same distance as your dim.
    If you notice most OE installed HIDs have extra housing for their halogen counterparts (used at the same time with bright function).
    I have tested the HID bright function for long range, and you'll be lucky if the light reaches 300m before your eyes. While my aux light halogens exceeded 500m more.
    Oct 2003
    One thing is for sure it's VERY EXPENSIVE!!!!
    just installed mine and had to fork out 56T
    I installed a pair of 100watt halogen aux lights for P1500.00... Lights up the road pretty well, too well sometimes because I'm blinding on-coming traffic.
    rebel::: Where did you bought your kit? It's too expensive, I had my kit ordered via the internet and it shaved my wallet 35K plus 1K for the installation.
    Oct 2003
    Ungas how many bulbs did you have on the 35K?
    Yun sa akin 4 bulbs lahat kasi seperate ang Hi and Lows.
    Just a pair of H4 adapter kits and a pair of D2S.
    Whoa! 4 bulbs? Ano pong sasakyan yang pinaglagyan nyo?
    Oct 2003
    Opel Vectra labo kasi ng halogen sa gabi pag nag bibiyahe ako.
    got mine for 24K...
    single beam.. 7000K
    mc cullouch..
    installed sa alfa romeo
    my car has xenon HID headlamps from the factory. coming from halogens in my previous car the difference is night and day (no pun intended) when it comes to short to mid-range lighting...HID is nothing short of awesome. the white light is also much easier on the eyes than the halogen yellow.
    i don't use the brights too much because streets are pretty well-lit where i live, but when i do use the brights they seem just fine for long-range use (even traveling at 100 mph).
    although i don't know if there are major differences between oem and aftermarket...i do know that my oem lights are in a projector-style housing and that might account for the difference. also, the bad effects of half-ass HID conversions are well-documented, from improper aiming (critical for HID), to uneven/splotchy beaming, and dangerous glare. some of these kits are worse/more dangerous than conventional halogen lighting.
    ...and let's not even get started on those fake HID colored bulb kits :bwahaha:
    Nov 2003
    i've got a set of raybrig foglights on my civic and i just got a set of HID's for my headlights. hehe! i can't wait to try them out as this week palang kakabit.
    this combination should give me the best of both worlds, near visibility with the foglights far visibility with the headlights
    Aug 2003
    speedyfix magkano mo nakuha ung hid mo at raybrig foglamps?
    meron ka na bang FCC clutch assembly?tnx
    Nov 2003
    foglamps are a bit more expensive than headlights. figure around 45-55T for the set. headlights will range from 20-35T also depending kung high-low sya and also the brand
    meron akong fcc and daiken na clutch sets.... just call the shop at the number below to inquire.
    thanks!
    Jan 2003
    Ungas,
    What's the URL of the site that you bought your HIDs?
    rebel
    Where'd you buy your HIDs for your Vectra? Do they have a set for the Tigra kaya?
    Cheers!
    Oct 2003
    rebel
    Cheers! [/B][/QUOTE]
    I bought the HID's from a friend who imported them in bulk.
    You can Private Message me so that i'll give you the contact number if you needed.
    I'm not sure for the Tigra since I think It only has one bulb.
    What I know is if 1 buld you won't have Highbeam or Lowbeam but just one beam for the HID. :freak:
    kamusta naman ang visibility ng HID during wet/raining conditions?
    Originally posted by green
    Ungas,
    They used to be available on this site, http://www.autolamps-online.com/gasd...low%20lamp.htm
    But I think they have redirected it to another site for their HID applications, http://www.hid-online.com/hidonline/home.htm Same company just another website.
    50K PhP for a HID?! Ang mahal naman, you can get it for $375.00.
    Also, If you have a double filament OEM bulb/lamp, you will loose HIGH BEAMS when you do the HID Conversion. But I dont think you would be needing the highbeam because the lowbeam is just like the highbeam. Of course, vehicles equipped with HID and are using a separate bulb for each beam will retain the HIGH BEAM.
    edit: also, HID Conversion works or owner can benefit more when they have a Projector headlamp.
HID anyone?
