Page 1 of 2 12 LastLast
Results 1 to 20 of 53
    Feb 2010
    Hi mga sirs,
    Tanong ko lang kung ano ang okay na brand for all-weather halogen for headlights and foglamps? Yung matibay at nagtatagal po sana ang buhay at syempre yung talagang makakatulong especially pag umuulan. Saka kung saan din po sana pwede bumili?
    Eto po usually yung mga nadidinig ko na okay na brands pero confused po ako kung alin sa kanila pinakamatibay:
    Narva
    Bosch
    Osram
    Flosser
    Have had mainly Osram and on occasion Bosch. Ok naman yung Osram.
    Osram.
    I'm using also Narva a/w on my HB4 Corolla headlights and they last pretty long too.
    Jul 2006
    Hella
    Bosch All Weather
    Osram.
    How's the output of the Narva? Medyo nabibitin ako sa Narva na nasubukan ko dati.
    Osram din ang subok sakin, 7 or 8 years ata tumagal sakin headlight na yun.
    i've used both narva and osram. generally ok naman.
    but i did have experience with one of them (forgot which)...pundi agad in a week.. and i swear the electrical and mechanical connections were ok..
    so i suppose there's still an amount of luck...
    and my unsolicited advice to those who find their lights too weak...
    have your eyes checked;
    see if you have forgotten that you had your windshield tinted...; and
    check your headlight lenses.. they may already be darkened with age.
    Jun 2012
    OSRAM just launched the new FOG BREAKER. It should be the better option for the bad weather.
    Aug 2004
    Quote Originally Posted by confused shoes View Post
    saan kaya merong available nyan dito, sir?
    any idea how much yung H3 bulb?
    Feb 2010
    salamat po sa lahat ng nagreply. i narrowed down my choices to narva, bosch or osram. among the three sino po kaya ang pinakamaliwanag? and kung may recommended ba kayong stores let's say in banawe na nagbebenta ng original? hella brand is okay too.
    Feb 2010
    confused shoes - ang fog breaker ba sir ay all weather or ito talaga yung pure yellow na for foglamps only and hindi pwede sa headlights?
    Jun 2012
    *blue_centrix, re: FOG BREAKER
    It's a 55w 2800K-2900K(within this range). Some say it is golden yellow.
    According to OSRAM it is 60% more light. It looks like better than all weather. For the all weather to have the same amount of light, it will be a 75w.
    Feb 2010
    dr. d - i'm okay with my stock bulbs except when it's raining at night.
    On the premature busted bulb, di you clean the bulb before you installed it? A probable cause was that someone may have touched the bulb glass portion. The oils from our fingers/skin can "bake" on the bulb glass when it heats up and cause it to go bust right away.
    Nov 2007
    I've used narva on my ex civic,it worked perfectly and bang for the buck,wala ako naging problem until mabenta ko yung car,it's alot better than my previous super white bulb that looks cool outside but terriblr when you're inside the car
    Feb 2010
    Quote Originally Posted by john5 View Post
    sir john5 - how long did your narva last? planning to upgrade first my HL and fogs to narva while saving for the retrofit budget.
    Aug 2010
    can you rank kung ano ang mas ma dilaw sa tatlo?
    1. osram
    2. bosch
    3. narva
    In terms of yellow-ness, I'd rank it as Bosch - Osram - Narva; but the differences are not too far off.
    Aug 2010
    any feedback on bosch all weather plus 60/55w?
    the bosch all weather is 100/90w, which of the two is brighter?
    Had a not so good experience with Bosch All Weather + 60/55W.
    Bought 1 pair during a business trip in Korea and when I came back and installed, I found the right HL with blurry cutoff.
    Root cause is the bulb is not straight with respect to the base causing out of focus light reflection. But the light is really yellow compared to the flosser semi-gold that it replaced which are already 10 years old but still working although it's already dim.
    Sent from my GT-N7100 using Tsikot Forums Mobile App mobile app
Reliable All Weather Halogen Bulb
