can you rank kung ano ang mas ma dilaw sa tatlo?
1. osram
2. bosch
3. narva
In terms of yellow-ness, I'd rank it as Bosch - Osram - Narva; but the differences are not too far off.
any feedback on bosch all weather plus 60/55w?
the bosch all weather is 100/90w, which of the two is brighter?
I use Bosch all weather's, 60/55w. Yellowish light, good visibility when its raining and in foggy conditions.
had my headlights installed with Narva all weather. very much satisfied with the the low and high beams on my civic fd.
Had a not so good experience with Bosch All Weather + 60/55W.
Bought 1 pair during a business trip in Korea and when I came back and installed, I found the right HL with blurry cutoff.
Root cause is the bulb is not straight with respect to the base causing out of focus light reflection. But the light is really yellow compared to the flosser semi-gold that it replaced which are already 10 years old but still working although it's already dim.
Sent from my GT-N7100 using Tsikot Forums Mobile App mobile app
thanks, trucker111. you've been very helpful. btw, few more questions if i do upgrade to a higher wattage.
1. is the bosch/osram all weather/season too yellowish for low beam?
2. sabi ng talyer na pinapagawaan ko, maintain 60/55w na lang kasi pag nag upgrade to 100/90w, mabilis na lalabo yun headlights. i'm changing headlights (assembly) soon.
A majority of todays headlight assemblies in most cars are made of plastic. As we all know, high temperatures and plastics do not go well after a certain period of time. This is why when I changed my bulbs, I chose to stick with the stock wattage.
I'm using stock Bosch All Weather's in my cars, (60/55) Php 499 in most ACE Hardware stores. To describe its "yellowness". The light throw has a tinge of yellow only. You will get to notice that when you're driving behind a white car at night. Low or high beams produce the same color of light. Compared to my stock Flosser and Narva lamps, I could safely say that they produce around 20% more light, maybe because they're new? I dunno.
I got all weather's because I always go up Tagaytay, and an occasional Baguio/La Trinidad trip.
Here's a good link for your appreciation; Daniel Stern Lighting Consultancy and Supply
Sir, in connection with this, pano ba inaadjust yung angle ng ilaw? Hindi po kasi pantay yung sakin eh. Thanks.
Sent from my GT-I9505 using Tsikot Forums mobile app
^Tamang tama lang yung pagka yellow ng Fog breaker para sa foglight. Size? You can not change. Buy the same type as your stock fog bulbs.
