Results 1 to 10 of 59
- Dec 2008
- 58
January 11th, 2009 11:23 AM #1I'm currently using Flosser 145/110 bulbs for my 97 Civic for almost 2 years na. I'm planning to install XenonWorx HID until I came across with these Philips Xtreme & Osram Nightbreaker bulbs.
Since the Civic is using a plastic headlamp cover and due to hot luminance of the bulbs, yung plastic cover gradually parang nagiging smoked sya.
Whether I decide to use Xtreme Power or Nightbreaker bulbs, would they still provide good luminance pa rin ba if medyo di na clear ang cover?
In regards dun sa plastic headlamp cover na parang di na masyado clear, is it possible to restore or even nearly restore its clarity by having the headlamps cleaned?
January 11th, 2009 11:31 AM #2
Most used car dealers will clean your headlamps for a fee. They do it all the time on the cars they sell. Look for the 'himas' boys in most used car lots like Autocamp, Axis, Red Central, etc.
If you want professional cleaning, Big Bert's also offers it provided you take your headlamps off the vehicle before sending it to them.
- Dec 2008
- 58
January 11th, 2009 11:48 AM #3
January 11th, 2009 11:53 AM #4
Yup. Nagagawan naman nila ng paraan depending sa type of damage.
- Dec 2007
- 142
January 11th, 2009 12:21 PM #5Since the TS already has higher wattage bulbs, will switching to Osram's NB give him better illumination than his previous bulb granted he had his headlight cover cleaned?
January 13th, 2009 02:51 AM #6
HID on a 97 civic will be dazzling...
seen a lot of them and it is damn blinding....
look at the HID 6000k-up car's light on the road they throw, not the light they throw on your face... compare it with a stock altis light. the altis is more likely to be more clear on the road...
for better visibilty purpose, better off with xtreme or nightbreaker...
for style without blinding other motorist, you have to convert it to projector like these civics...
- Nov 2005
- 30
January 13th, 2009 09:12 AM #7since you're currently using high wattage flosser 145/110 watts, very minimimal lang yun difference sa light output/luminance with nightbreaker or Philips XP, considering XP & nightbreaker is 60/55W only.
Just imagine more than 2X wattage but will give the same luminance w/ NB or XP.
January 18th, 2009 04:28 PM #8
- Dec 2007
- 142
January 19th, 2009 02:07 PM #9nice ganda sir! how much did the clean and smoked headlights set you back?
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
