Results 21 to 30 of 63
- Aug 2010
- 278
March 26th, 2011 03:48 PM #21
November 22nd, 2011 06:47 AM #22
I've been using the OSRAM All Weather 60/55 watts for almost 2years now. I got no problem on it on my Revo GL 200 model since then. What I only plan now is to add relay on it and most likely replacing my stock socket to ceramic sockets to enhance it's power. I'm not really a fan of using high wattage bulbs since it will most likely dim your headlights like what I've experienced with my previous cars. if you want to have your HL a little bit more brighter while staying on the safer the side of the experiment. Replace your oem bulbs but with something close to the recommended wattage for your HL then just add relays to it. Try it first then if not content with it, opt fro the higher bulb watts instead. I personally do this first and even my friends do it now as well. Safe and mas mura pa. Anyways I always get my bulbs at Goldrich in Banawe. Lagi kasing meron sila ng mga hinahanap ko eh
January 13th, 2012 02:38 PM #23
Share ko lng mga sir i have been using wurth all weather 60/55s for two years and still ok siya,sulit sa tibay,liwanag pa.perfect for occasional trips to tagaytay lalo na at foggy,rainy paminsan.medyo addict ako sa h4 all weathers kaya meron na akong spare if ever mapundi na wurths ko hehe.next in line would be narva, then osram.hehe solid h4 all weather fan eh hehe.peace
January 13th, 2012 03:42 PM #24
SIR maganda din po ba ang circuit na h4 all weather? 90/100 made in japan daw po? i check nasa 180 lang ang isa...
January 13th, 2012 10:23 PM #26
if you have the time search for Philips H3 na rally version.. 100watts yun tpos 280 pesos lang ang pair...most powerful bulbs you can put for your fogs!
then you can try zoomlite bulbs if you want less than 500 per pair... its another option besides the most popular one's like philips extreme vision , narva, bosch all weather, osram night breaker... it really all boils down to your preference...
- Jan 2011
- 34
January 15th, 2012 07:27 PM #27Tanong po, meron kasi ako nakita na narva na mga headlights sa robinsons metroeast handyman kaso nasa ordinary box lang yun isahan. Same lang po ba yun sa mga performance bulbs nila kasi yung mga common ko na nakikita sa internet is by pair na. Saka meron pa po ba na pwede bilihan mga mga head light bulbs na malapit sa ortigas. Thanks.
January 16th, 2012 02:47 PM #28
mag narva ka na lang boss,cheap,safe and useful upgrade.proven and tested ko na yan=)wag ka ng mag taas muna wattage kelangan mo din kase upgrade buong assembly mo pag ganun pati yung lens mo mangingitim
- Feb 2012
- 39
February 20th, 2012 09:18 AM #29
- Feb 2012
- 39
February 20th, 2012 09:23 AM #30sir sa honda civic po pala ano po recomend niyo at ilan wattage,ung hindi po masusunog ung reflector ng headlight..thanks
I think they took over Sept 2023... I remember their event presented the 296 GTB and the Purosangue...
Car Sales Data (2024)
