Results 1 to 10 of 12
- Dec 2006
- 42
June 11th, 2007 06:46 PM #1I need some help peeps. It's a very weird problem but its there and i can't tell why. I recently installed HID lights on my ride. And i just noticed today that when i turn them on, my FM radio signal weakens and i start getting static and signal drops. What can be the problem here? Help please!
June 11th, 2007 07:18 PM #2
weird nga, but eto sa tingin ko, since may balast ang hid baka malakas ang EMF emitted by it. kaya naaapektuhan radio mo. watching too much Mythbusters ata ako hehe
June 11th, 2007 09:52 PM #3
June 11th, 2007 11:55 PM #4
^isn't in that HID's consume less power (35w) compared to stock halogens?
well i think its more of interference or bad antenna connection.
June 12th, 2007 02:16 AM #5
palipat mo ng lugar yun ballast. baka malapit sa antenna cable or the antenna itself.
June 12th, 2007 04:44 AM #6
I'll also suggest that you relocate the ballast first and make sure the connections are good. A device producing high voltage spikes (like HID systems) will make noise, and noise has a funny way of choosing its route.
Check mo rin antenna connections ... There's a BMW service bulletin regarding the E36 antenna plug (going to the head unit). You may also want to check the antenna connection to the antenna booster located in one of the C-pillars.
June 12th, 2007 05:28 AM #7
Mang dencio is right. Check your ground make sure your ground wire is grounded properly to your chassis(paint must remove) or engine block use star washer for better contact. If this thing dont work, try to isolate your HID ballast from the chassis use rubber grommets if attaching your ballast to the chassis or install an antenna noise supressor. Good luck
- Dec 2006
- 42
June 12th, 2007 12:43 PM #8Okay thanks for the input guys! i'll try to relocate the ballast and see what happens. If that doesnt work i'll check the grounding of my radio then. Hopefully i can do this soon cuz i'm getting busy with school starting! Thank you very much for the help!!
- Dec 2008
- 421
December 18th, 2008 09:25 PM #9yup, your ballast might be too near the radio reciever or wires. try relocation it or put some shielding on your ballast.
December 19th, 2008 03:26 PM #10
it's not Higher currents but Higher voltage, about a few thousand volts.
anyway, I am skeptic relocating the ballast would help. I have a fella who has the same case. his ballast is malayo naman eh... and the ballast itself is making that noise parang am station noise... unfortunately, hindi pa nya na solve...
if other suggestion didn't work, try relocating your HU's negative source directly to the battery.Last edited by rion; December 19th, 2008 at 03:31 PM.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
