Results 51 to 55 of 55
- Feb 2012
- 39
March 8th, 2012 12:39 AM #51ang osram night breaker po ba,all waether din? parang kulay puti ata ilaw nun,
May 17th, 2012 09:36 PM #52
on super yellow bulbs:
meron po bang 55w pero ang output nya e 100w like sa ibang halogen na nakalagay sa box stock wattage pero output nya is something around 100w? sa box kasi ng solarzen wala akong makita, sa euroline kaya? or any other brand, wag lang expensive
May 18th, 2012 09:10 AM #53
White-ish ang Osram NB. It's not diamond white, but it's whiter than stock. That gives you the impression that it's more powerful than the stock 55w power. It's definitely not all-weather.
I really don't pay much attention to that type of packaging. But in terms of output, Solarzen and Euroline have about the same output for the same price range for super yellows. I think PolarG is more powerful, but more than twice the price of the earlier two. If you're ok with less than super yellow, Osram all weathers should provide a bit better illumination.
June 2nd, 2012 07:57 AM #54
pinaka ok na nakita ko na halogen bulbs. 90/100w or 85 wlang ata merun sila pag single beam pero sa h4 hilo 90/100w flosser pa din. 400 isang bulb dati 350 lang.bili lang kayo sa mga auto supply dun sa banawe. mas ok pa din visibility nito maski umuulan at aspalto ang daan. believe me. ndi bias yan suggestion ko. i only sell hid . wala ako carry na flosser brand. yan gamit ko dati sa lahat ng vehicles namin ndi na ako nagparewire pero better if pa add kayo relay. now kasi i use hid na. pero ndi kasi lahat sangayon sa price ng hid kaya yan ang best alternative. with respect to osram and philips users ok din siya pero kung ikompara ang lakas nito sa ulan flosser ako. mataas nga lamg wattage pero its cheaper
November 1st, 2012 08:34 PM #55
I've used Osram and Narva as far as all-weather bulbs go. Both are effective in any conditions, especially rain, but Narva is almost half the price per bulb so I went with that. Narva is also a little more readily available compared to Osram. With the Narva bulbs I can carry a spare pair of headlight bulbs for the price of one pair of Osrams.
Willing to try other brands, though - I hear Auto Express rated Philips' Vision Plus bulbs very highly.
high idle RPM at engine start
