Results 1 to 15 of 15
    Feb 2004
    Mga masters,
    Malapit na matapos washover ko. Im planning to replace the head and tail lights para magka dating naman ang oto ko..hehehe. ano ba magandang mods sa head and tail lights?
    I heard about crystal headlights, yun ba yung parang blackish yun lens? Any recommendations and shops where I can get a good deal. Trade in sana para madispatsa ko na yung stock lights.
    Tnx.
    Jan 2004
    ano auto mo? if i were in your shoes, i'd get the 'smoked' head lights. as for the rear, euro would be ricey so i'll get the one with white signal lights instead. hanap ka sa banawe marami dun. :D
    Jan 2004
    Jan 2004
    Feb 2004
    smoked? ano itsura non? how much for a pair including the corners?
    Feb 2007
    smoked headlights can be done DIY style. All you need is a heating appliance (oven, heat gun, etc) to separate the glass lens from the cover. Then spray lightly with high temp paint, both black (or gray) and clear. Just be careful to seal the cover to the lens back neatly.
    wow, 3 year old thread
    sir,more info about the diy smoked headlights.. wat adhisive ung gagamitin sa pagseal..
    Feb 2007
    Quote Originally Posted by zx6rr View Post
    Found this in the other forums. Kudos to Cole Grey:
    http://www.pbase.com/paintedheadligh...dlights&page=1
    Quote Originally Posted by shampooking View Post
    bro,thnx so much for the link.. very much appreciated..
    Feb 2006
    bro, pm mo si sir hotwheels about sa smoke headlight, may alam sya regarding dyan...
    any information on how this can be done on 98 civic headlights? baka may links din po na katulad nung sa lancer.
    Feb 2007
    Quote Originally Posted by jpestrada115 View Post
    Check first if your headlamp assembly is made of plastic or glass. Kungglass, pwede mo i-bake sa oven para matunaw yung seal. Careful, hot! Kung plastic, use a heat gun para concentrated yung init sa seal lang.Pry open with a cutter. Initin uli pag ibabalik para dumikit yung seal.Kung kapos na yung sealant pagbalik, add elastomeric sealants na langor rtv silicone gasket. Pag projector type lens mo, doble ingat. Or trymo kay hotwheels para wlang problema.
    salamat po!
    plastic sir eh. hanap muna siguro ako ng heating gun
    hilig kasi ako mag-DIY eh.
    May 2007
    pwede rin gamitin yun hot air yun pang repair ng cellphone..may control ng temp..
    makikigamit na lang sa kakilalang repait shop ng cellphone
Headlights and taillights mods?
