Up natin yung thread.
Still waiting for walter's experience. Nakakaintriga yung comment nya eh
Oh ... one of the headlights retrofitted became hazy ... one of the the park lights wouldn't work after 3-5 months ... turns out the park light bulb was loose ... plus the bumper wasn't placed properly when it was removed so a section was a bit deformed when it was re-installed ... to each his own ... most have good experience with hidretrofit.net ... mine wasn't as good ... so next time would be trying out the others ...
^ oh. Fair enough. Napa warranty mo ba yung hazy side?
Baka nataon lang din. Oh well.
My experience with HIDretrofit: Loose connection on the part where the fuse is inserted. Only connected by electrical tape. There are times that it won't power up so I have to pop the hood and wiggle connection for it to light up. Happens around 5 times per year. It is now on its 4th year, thus warranty is already out. I changed the bulb on the 3rd year(DIY), the ballast is still unchanged. Scratches on the bumper when the headlight was removed. Installation was a bit rushed, there were three of us being worked on, at the previous taguig location. Installation took 3 hrs. I would probably change it to LED after the bulb performance declines.
Experience with retrotech: Wide variety of options for projectors, shroud and bulbs. My specifications were met and paid way less than HIDretrofit's. I liked the quality of the install better. Sole customer being worked on. It took a whole day but atleast installation was well done. No issues so far after a year. All of my questions/doubts(due to not so good experience from above) were adressed and well explained.
Planning to check xenon concepts for the next project if their prices are competitive.
How does firedrake fare?
may maintenance bang kelangang gawin when you retroffited your headlights? i mean forever na ba yung projector, yung bulbs and ballast na lang ang papalitan?
also say biglang napundi yung one side eh nasa province ako where the availability of these things are close to zero, ano pwedeng gawin?
Matagal ang buhay ng branded HID. Yung stock Osram Xenarc HID bulb ko is already 6 years old. Malakas pa rin ang ilaw. Pinalitan ko lang kasi gusto ko mag-try ng ibang series at color temp. I switched to Osram CBI Xenarc HID.
Sent from my ASUS_Z010D using Tapatalk
Yung projector, forever yan. It is just a housing part. Yung ballast, forever din unless masira. It is electrical part. Yung stock OEM ballast ko (Mitsubishi Electric) is already 6 years old. Still no problem.
Projector ung stock na ksma sa cx7
Sent from my SM-A720F using Tsikot Forums mobile app
I cant find any philips zed led. All are saying using philips zes board gen2. Where can i purchase a real philips zes led?
Sent from my SM-A720F using Tapatalk
Inquire here:
D3 Technologies - Home | Facebook
