Page 8 of 22 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 717
    Quote Originally Posted by red_one View Post
    *xtian09: ilan months warranty ng Osram NB+ H7 mo?
    One week sir after proper installation and not touching the bulb. So far, no one from my buyers had a problem with
    Osram Night Breaker Plus after they install it in their cars. And based on my friends experience, yung Osram NBP H4 nya lasted for 2 years.
    Regarding the one who installed Osram NBP and said:
    "bakit ganon, sinubukan ko high ng NB+ h4, ang pusyaw ng buga..... malabo kumpara sa dating gamit ko na osram all weather.
    pag dark ang color ng kalsada, akala ko pundido na agad mga bumbilya ko. nawawala."
    Sir, try to re-align or focus again your headlight. Everytime we change the bulb, we also need to align/focus the headlight. Baka kasi sobrang taas or sobrang baba ng ilaw kaya malabo. And NEVER touch the bulb/glass coz it will decrease the light output.
    The reason why Osram NBP has a yellowish color and 10% whiter than stock bulbs is for the driver to see the road even if it is raining. Kasi if white sya e magbo-bounce or magre-reflect lang ang ilaw sa wet roads.
    Regarding Extreme Vision, maganda and malakas din sya. Pero malaki ata difference sa price compare sa Osram NBP. Do you have an idea how much Extreme Vision is?
    The satisfaction on which bulb to use depends on the end user. Some are satisfied with Osram NBP and some are not.
    You can use any brand of halogen bulb but just be sure that it is worth the price and always think of your safety.
    Quote Originally Posted by babynos01 View Post
    Sir SG, mas maputi siya compared sa stock halogens or sa philips XV?
    Mas maputi than stock and Philips XV. Yun Philips XV close to stock halogen ang color but definitely mas malakas.
    Sent from my LT26i using Tapatalk 2
    Sep 2009
    *xtian-di ko maiwasang hindi mahawakan yung bulb.
    big no no ba yung ginawa ko?
    and whenever i change bulbs i see to it that my hands are clean. if ever ba puwede kong punasan yung bulbs? thanks
    Feb 2006
    Sir ,
    You can try using Latex gloves , yung ginagamit sa clinics or hospitals hehehe parang me ooperahan ka nun
    Our hands have oil( natural) that may cling to the bulb and causes it to be burnt during lamp operation thus shortening the life of our bulbs.Minsan kasi di natin pansin masyado kasi malinis yung hands natin pero trust me the oil is there.
    Just my two cents sir , hope this helps.
    Quote Originally Posted by threx666 View Post
    Sir ,
    +1
    Or if you don't have Latex gloves, you can put baby powder on your hands to absorb the oil.
    Sep 2009
    ^ok. pero bakit yung osram all weather ko. may ilang beses ko ng kinakalas kasi yung alambre na clip laging nakakalas at nalalaglag sa loob ng housing. talagang hinahawakan ko na yung bumbilya. mag 4 years na yung osram all weather ko. or 4 years na ata?
    Sep 2011
    Thanks sir SG. I was able to research on the color temperature of the bulbs and mas mataas yunn NB+.
    Philips xtreme vision * 3000K
    Osram NB+ * 3500K, 1550lm
    Quote Originally Posted by holdencaulfield View Post
    Good for you sir! Pero hindi ba nabawasan yung lakas ng ilaw nya?
    Aug 2012
    nakabili rin.. masubukan nga ang lakas nito..
    Jun 2010
    hi guys,
    my company assigned me a 2008 altis 1.8 v and upon researching stock headlamps is HID (with manual levelling) - though I'm still not sure if the stock HID is still the one installed on the car The thing is, I just came from North Luzon, and upon traveling at night at SCTEX, I had a hard time seeing the road especially the parts with no lighting at all.
    In your opinion, which should I go for?Philips Extreme or Osram Night Breakers Plus? or HID (which brand?)? I'll be travelling outside metro manila more often than not, and I heard you'll have a hard time seeing the road when using HID during heavy rain fall.
    tia!
    Quote Originally Posted by d_rookie12 View Post
    hi guys,
    tia!
    Based on my experience with 6000k HIDs, i have better vision during rainy days with it than stock halogens. Upgrading to NB+ or XV will surely improve your lighting if you're currently using halogens in your car.
    The thing is with HIDs is that, you need to be a responsible user. Some reflector headlights can handle them, some cannot. If you stand in front of your car and get a face full of glare from your headlights, it is better to stick with halogens. Not everyone can afford a retrofit, so if you are planning to get HIDs, make sure you don't cause too much glare to other motorists.
    If your car uses H4 bulbs, it is almost certain that when you switch to HIDs, it will have terrible cutoff. 9006 bulbs on the other hand, has a nice cutoff even with plug and play HIDs.
    hi guys,
    tia!
    sir, i would suggest you get a retorfit from GaryQ for your low beams. pricey but well worth it if you can afford it. i dont think bolt on projectors will fit in the low beams of the altis. so the only other option for you is to replace the oem halogens with Phillips XV or Osram NB+, sigurado meron improvement ng 35% (as they claim). also, you can replace your hi beams with these bulbs. ganyan din yung xtrail ko with oem halogens, it was inadequate when i traverse the sctex at night. at first, i replaced it with high wattage high priced IPF halogens and replaced the sockets with ceramics. kaya lang ang bilis mapundi. halos 1 year lang. then i replaced it with HID bulbs, malakas tignan pero sabog ang nakaka silaw. so i replaced it with G3 bi-xenon projectors kasi cant afford retrofits. ayun, happy na ako sa buga ng ilaw at sa cut-off. di na nakaka silaw.
    yung accord namion, di rin pwede bi-xenon projectors kaya replaced both lo and high beams with philips XV, better than the oem halogens.
    Sep 2009
    chineck ko yung NB+ ko kanina. closely inspected them, so far no oils, finger prints or anything that make my hands the culprit ng panlalabo. napa-ingat ata ako sa pagkabit.
    compared to my other bulbs na osram all weather na madami talagang fingerprints.
    sorry to say, hindi talaga ako satisfied sa NB+, may mga kalye na ang ganda ng buga niya and meron talagang parang wala talaga. since city driving palang ako sa ngayon, minsan ko lang nasubukan yung high. triny ko dito sa scout tobias yung high, fair lang talaga.
    ewan ko baka kailangan pang ipa-align nga yung HLs ko o baka naman peke yung nabili ko.
    Saan mo nabili sir yung Osram NBP? Yes, may mga fake na Osram and you can see the difference sa packaging pa lang.
    Have you checked yung takbo ng electricity ng oto mo sir? Or baka maluwag yung pagkaka-lagay ng socket sa bulb?
    Or try to align your HL.
    Quote Originally Posted by xtian09 View Post
    Ano itsura ng packaging nung fake?
    Aug 2007
    where can i buy osram nb+ H7 in banawe na P 1100.. most ng mga natanungan ko around P 1500
    Quote Originally Posted by sagingsaba View Post
    sir bought mine, genuine, for 900 lang. txt Bodj 09151801803
    Pale yung color sir and yung hologram na sticker sa ibabaw ng box is hindi clean and yung silver sa front printing is hindi kumikintab pag natatamaan ng ilaw.
    So haulden mas ok talaga osram all weather? Magkano ba yun?
    Sent from my GT-P7310 using Tapatalk 2
    May peke ba nito? Baka peke rin yung nabili kong philips xv, ganiyan na ganiyan din eh, minsan mahina minsan malakas(malayo kasi buga).
Philips X-Treme Vision Vs. Osram Night Breaker Plus
