Page 16 of 22 FirstFirst ... 6121314151617181920 ... LastLast
Results 301 to 320 of 717
    Aug 2012
    Quote Originally Posted by LancerA174A View Post
    Guys will these fit projectors too? Sorry medyo noob question. And are they really better than fairly new stock bulbs (less than a year old)?
    Basta same bulb type, magpi-fit siya. Yup, mas maliwanag sila. Kita mo naman ang illustration sa likod ng Osram packaging above.
    Jan 2013
    Quote Originally Posted by red_one View Post
    I see, I don't usually trust self-claimed improvements kasi that's why I asked your opinions. Thanks btw
    Aug 2012
    If gusto mo ng testimonial, you can backread this thread. Philips XV user ako. H4 bulb type in my previous car. Tapos ka-o-order ko lang now ng Philips XV, HB3 type naman for the new car.
    Which shops sell Philips XV 130%? Aside from online shops.
    Aug 2012
    Changed high-beam headlamps of Mitsubishi ASX to Philips X-treme Vision HB3.
    Jun 2012
    question lang po...
    malaki ba difference between retrofit conversion compared to osram nightbreaker/Philips Xtreme Vision? that is, aside from price, and complexity of installation of retrofitting...
    with regards sa performance lang... especially with lowered cars...
    thanks in advance!
    question lang po...
    thanks in advance!
    Mar 2007
    *scaryghost: Night and day ang difference when using retrofit projector lights in comparison sa halogen light, basta tama yung pag retrofit (use FXR or A3 lenses if you can)
    Aug 2012
    Quote Originally Posted by scaryghost View Post
    question lang po...
    thanks in advance!
    Compared to standard halogen:
    Philips XV gives 100% more light.
    Osram NBU gives 110% more light.
    HID gives 200% to 300% more light.
    So yes, malaki ang difference sa light output.
    HID glare can be particularly annoying for other road users. As such, they should always be aimed towards the ground.
    Jun 2012
    Quote Originally Posted by Gecko Guy View Post
    thank you very much sa inputs!... will go hunting for retrofitters..
    There are only 2 good retrofitters that I know of - GaryQ of HIDretrofit.net and Tots of Redline Auto Works.
    Mar 2007
    Same opinion with jut703! You can never go wrong with Gary or tots. Gary did mine by the way.
    Jan 2013
    saan ba shop sa banawe makakabili ng osram nb?
    Quote Originally Posted by bhongchel View Post
    Dami. Halos lahat meron.
    Oct 2013
    no need na mag banaue, sa sm ace hardware lang meron na...
    Jan 2013
    thanks!
    Quote Originally Posted by Stigg ma View Post
    nagkakabit din ba sila dun? fd kotse ko.
    Jan 2013
    thanks!
    Oct 2013
    No need to wear gloves. Basta lang wag mong hawakan yung bulb mismo, always hold it by the base.
    This is because the oils on your hand can get on the bulb, causing it to heat up during use, then poof, premature death.
    Mar 2013
    +1000
    Never ever hold the bulb with your bare hands/fingers.
    Aug 2012
    Do not worry too much. If accidentally mahawakan ang glass part ng halogen bulb, just wipe it with soft cloth and isopropyl alcohol until your fingerprint is gone. Next, wipe with soft dry cloth. That's it.
Philips X-Treme Vision Vs. Osram Night Breaker Plus
