kung ordinary stock wattage bulbs siguro nasa price range of 100-150php. yan kasi yung price range ng narva, flosser and philips na ordinary stock wattage bulbs.
osram 100/90 watts 12v stock color P275 each sa wizzards
sa reys P250 ata ito.
isip ko lang preferred brand kaya ng reys n wizzards ito?
if i have the 100/90 watt osram silverstar installed do i need to put a relay?
yes i suggest you put a relay and upgrade your wiring as well. i saw a narva kit which sells only for Php 550Originally Posted by geode
sir suntzu, san nyo nakita yung narva kit na yon? isang set na ba yung Php550?
yup sa handyman mahal yung narva wiring kit (130/100w) mga 1.5K ata last time i checked. paging suntzu, san mo nabili yung narva kit? its a steal eh hehehe
dati meron kina glenster na wiring kit.
P600.00 noon, pero cant remember kung anong brand
sa evangelista ko nakita. if you're coming from edsa. sa pag kababa ng tulay. kalimutan ko name ng shop pero between 550 to 650 ang price. yup, nakita ko ung sa handyman and ganong ganon ung narva kit sa evangelista.meron atang Php 350 kaya lang Type R ang brand. :freak:
suntzu \
reliable kya yung shop na yon, ,meaning all orig kaya benta nila? isip ko kc baka mas mura benta nila ng mga 100w+ na h4 bulbs
Originally Posted by buknoy2002
hindi ko na na i-scrutinize na maigi. pabalik pa kasi ako sa office non.![]()
been using osram for several years na. tried na the philips and piaa din. yung philips na crystal vision is ok and the diamond vision but very expensive. yung piaa sobrang mahal but i was very disappointed (marketing lang ata). osram is the best considering the price, how can you go wrong with 900 bucks. try and search also sa mga reviews and you will see the osram silverstar is always on the top 3. +50% light on the road. stock wattage so no problem. you really have to use combination fog/drive lights to get the most out of these stock bulbs. on my trooper before i had the main headlight, a fog light mounted on the lower side of the bumper for foreground illumination and drive lights for longer throw (driving at higher speeds). This set up has proven to be the best combo for me short of buying the HID. Ganito rin ang sa EG6 ko (no drive lights) Of course hid is a different story incl. price, he!he!
sensya na po sa tanong ... whats the difference between a "drive" light and the headlights?
drive lights yung nasa baba ng headlights. misnomer yung common na tawagin ay foglights. Foglights are usually yellow
ayun! un pala un! hehehe tawag ko din dun foglights hehethanks for the clarification pre.
i see. yun pala yun. hehe parang yung sa lancer na bago. fogs are usually yellow nga. ang drivelights only provide more lighting to the places that the headlights miss.![]()
add ko lang, fog lights and drive lights are different. fog lights has a wide beam pattern with a shorter light throw. mounted close to the ground para kung umuulan di bumalik sa driver ung light hitting the rain. kasi nga nasa baba na eh. so ung daan lng matatamaan nya. also good for cornering, kasi rin po wider ung light pattern nya. so correct mounting ng fog lights is closest to the ground. while drive lights is just the opposite. narrow beam pattern with longer light throw.![]()
