Noob question.. But will hid still give as much glare if the headlight is already smoked? Since everythings blacked out aside for the reflector bowl?
Eg.
http://cdn.sulitstatic.com/images/20...b9843d2a5e.jpg
*pic grabbed
Sent from my SC-01E using Tapatalk
as mentioned in some of the previous threads here, a properly retrofitted HID system will not have any glare since it has a projector that focus all the lights on the road. also the projector has a cut-off, that means walang glare above the cut-off line. but even if you have a properly retrofitted hid projector, you still have to make a good alignment since hindi lang ang on-coming traffic ang pwedeng masilaw sa hid natin. we also have to consider the car in front of us that is traveling in the same direction sa atin. dapat at about 25ft our cut-off should be below the side mirror of the car in front of us. check this out for comparison.
proper hid retrofit usually starts at around 11k for aftermarket setup and can go up to 26k-30k+ for eom setup. but that still depends on the retrofitter and the add on's your planning to put on your setup.
here's my morimoto mini h1 with foglights sa highway kagabi. hindi na kailangan mag-high beam kasi anglayo ng bato at the same time walang glare.
Rule of thumb:
Want to upgrade light output on a tight budget = Osram NBP/Philips XV
With (a bit of) budget - Go with Projectors, no doubt. Kahit entry level lang, worlds apart ang difference compared to PnP. I saw an underbone MC retrofitted with HID projectors, sobrang ok ng output, and props to him for deciding to go projectors.
Iba talaga pag sa SUV/Pick up nilagay ang projectors, mas malayo ang light throw kasi mas mataas yung position ng HL. Sa sedan kasi, pag sinagad mo yung taas, tas pag may sakay ka na, titingala. Nakakasilaw na. Although sa sedan, mas slightly intense ang buga sa center dahil mababa. My observation.
Just installed osram nb on my super grandia. Very happy with the results. Got it from autobacs banawe for 1.2k.
May h11 ba na Osram? Parang wala ata sila website eh
Sent from my GT-I9082
Wow! Aius na talaga ang buga ng projector.. Hindi comparable sa "just headlights"
Nakaka excite kaso it comes with a price.
hope maging stock feature na ang projector lights sa lahat ng vehicle in the coming years.
For safety and performance narin for the drivers.
1k kuha ko for h4 kay c3 audio.
HID in a projector is the best. It's literally a night and day difference.
Recently had our Tucson retrofitted by GaryQ (hidretrofit.net).
Headlamps before and after conversion:
Beam Shots: BEFORE: Low- and high-beam (OEM halogen bulbs):
Beam Shots: AFTER: Low- and high-beam (Stage 3 - 35W HID Projectors)
nasa del monte kasi ave. ako kanina kaya sa Cartronics na ako bumili. 1.1k bigay sa akin sa NB+ tumawad pa ako kay ate Emie, sagad na daw yun dapat nga daw 1.2k.
tapos late afternoon nasa banawe ako may dinaanan. sayang din yung 100 natipid kung sa c3 ako bumili, 2 liters of gas din.
*topic
HID ako, kaso mahilig ako gumamit ng highbeam sa pag-oovertake/ako muna dadaan sir stop ka muna. kung katulad lang ng civic FD headlight ng ride ko na magkahiwalay yung bulb, 100% sure HID papakabit ko.
^ yup maganda quad kaso need magpalit ng headlight at bumper sa crv gen2 (pre mmc), wala budget.![]()
