Normally to turn on the front foglamps in most vehicles, you need your headlamp switch to be at least in parklamp mode (except for U.S. vehicles which require you to be in low beam only to operate foglamps).
So if you switch the foglamp switch to "ON" and the headlamp switch is in the OFF position, the front foglamps will not illuminate.
My brother used to have an '01 Sentra (it's with my uncle now). And instead of the foglamp switch being governed by the headlamp switch, it seems to have a mind of its own. When you depress the foglamp switch, it also turns on the parking lamps, instrument panel lamps and license plate lamps. This even when the headlamp switch is in the OFF position. I thought this was just due to poor wiring (the foglamps were a dealer-installed option) and never bothered to have it fixed.
Last week I was driving a Nissan Urvan with OEM foglamps built into the headlamp cluster. When I depressed the foglamp switch, it also illuminated the parklamps, instrument panel lamps and license plate lamps. The main headlamp switch was still in the OFF position at this time.
Are Nissan cars really wired this way? With the foglamp switch able to override the main headlamp switch? This is the first time I've encountered such a design and I find it a bit wierd.
Thanks!
