Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    well 1st things 1st, I have a vision problem when at night time, parang malabo na ang Tingin ko, di namna sobra pero parang sa madilim, i'll just with the slow gear kahit na freeway ung dinadaanan ko. additional pa, i think ung headlight bulbs ko is worning out.. medyo malabo na xa, parang malapit ng mapundi, Im thinking fof changin my bulbs with a new one.
    the thing is, I need suggestions on a bulb, that would have a good and bright light, Im thinking to have Osram or Philips? also, i have a Frosted lamp, ( im using a 1996 car) so Any Suggestions? di daw kc applicable ang white bulb (HID LOOk) sa Headlight ko eh, kc nga Frosted daw.. need help on this ASAP!!
    OT: meron bang Crystal lamp for a 96 Honda City Exi? if yes, saan?? how much? may contact Number ka? anung name ng shop/store?
    Thanks tsikoteers...!!
    use narva all weather lamps. mas bagay sa iyo yan na medyo mahina-hina na ang vista. if possible, have your headlamp wires upgraded so it can handle a higher voltage compared to stock.
    stay away from the HID look. they don't work. real HIDs are better.
    and BTW, I have Magic Blank Tints, including the whole front Mirror.. mas Ok ba tlga All weather? and correct me if im wrong the The Higher the Wattage of the Bulb, the the Brighter it would be?
    Quote Originally Posted by mackkcam View Post
    an option for you is to remove your front tints and replace it with a lighter one.
    yes, the higher the wattage, the brighter it will be, but i personally think it has got to do with the bulbs. kung pure white, na HID look, useless maski mataas ang wattage. but, if you try to use the yellow ones as well as the all weather, kitang kita difference.
    i had the dilemna like you months before. my car is tinted super black, including the front windshield. had it installed four years ago and it suits me fine, even while driving at night. tapos, the past few months, i noticed, medyo nababawasan na visibility ko (siguro tumatanda na). thought of removing my front windshield tints and replacing it with a lighter one, but i really cannot sacrifice the privacy that dark tints provide (nakakapangulangot ako while in traffic eh...).coupled with that, my tints still look new.
    so i went to the next and more expensive alternative.... installed HID's... hehehehe. i am happy now.
    also, one of my Peers here at work told me, " if i were you, i would go for the HID Bulbs" kaso, the problem is frosted nga ung Lens ko hindi xa Crystal, medyo Ok cguro xa kung Buong Assembly ang papalitan ko... Comments?
    Oct 2005
    HID bulbs aren't good with stock housings...mas maganda if you install HID bulbs with lamp housings which are made for HID bulbs.
    If I were you, all weather lamps ako.
    Oct 2005
    2x post mods...sorry
    Jun 2007
    Im using Osram "hyper" 80/85 all weather medyo yellowish siya pero malakas ang buga! maganda talaga siya hindi kinakain ng spalto at rain
    naka full tint pa ako sa windshield niyan
    White bulbs = pure anesthetic purposes only hirap talaga makakita sa gabi lalo na pag umuulan
    regarding sa crystal headlamp meron niyan sa evangelista
    Thx sa mga Info, share ko lng ung nakta ko ung kakambal ko na car sa may Place namin, One time kc nakasalubong ko ung kakambal ko na kotse sa place namin sa pateros, napancn ko ung Headlight nya nakaLow pero ang liwanag, nakkhiya naman cguro kung iattnung ko kung anu ung Headlight Bulb nya di bah?
    Anu kaya Wattage Nun? mga anu ba preferrable na overwattage na All Weather Bulb?
    *Washburn,
    Saan sa Evangelista? lam mo name ng Shop? pati Contact Number?
    ung Mismong Lens Ung Frosted, meron para sa Model ng Car ko? Honda City Exi?
    Aug 2004
    Quote Originally Posted by washburn View Post
    bro, saan mo nabili yung osram hyper bulb mo? how much? kasama ba installation? naghahanap din kasi ako. thanks.
    Jun 2007
    *mackkcam sir siguro yung nakasalubong mo naka HID yun or naka 100++ watts na yung bulb niya, pag naka 100++ watts bulb ka you need to replace the stock socket to ceramic para hindi masunog yung stock socket, plastic lang kasi ito
    regarding dun sa crystal headlamp , anu po kailangan niyo yung stock o crystal? (yung clear talaga) kasi po sa evangelista maraming parts ng headlights e different model regarding po sa car niyo meron naman "siguro" niyan pero di ko po guaranteed na meron pero ok naman kung try niyo diba?
    *mcbry bro Osram Hyper 80/85 nasa 480 each H4 (hi/lo) bro kayo nalang magusap nung nagbebenta pero madali lang naman install yan e
    ito number niya 09185702232 MOND pangalan niya sabihin mo nirefer ni washburn, pero definitely kaya niya install ito free of charge! mabait kausap yan!
    advice ko din po na magreplace ng cermaic sockets to play safe lang painstall mo narin sa kanya yun mga 150 pesos lang po yun 2 na!
    HTH
    HTH
    bro san ung evangelista? sa san juan ba?
    Aug 2003
    evangelista is in makati not san juan. it runs almost parallel to the south super highway until arnaiz ave (pasay road).
    mga magkanu kaya aabutin ng papalit? sabihin na nating Over wattage ung Bulbs ko for the headlight, isang palit lng ba ung plastic to Ceramic? i mean kahit mag palit pa ako ng mas mataas pa sa Currently kong i-install ngaun? ok lng xa? for example: 80/85 currently na papa-install ko ngaun, tpos sabihin na nating next year 100+ kahit di ko na palitan ung Ceramic Socket? magkanu pa paChange ng plastic na socket to Ceramic na SOkcet?
    Jul 2006
    Why don't you put a lighter tint instead, for the safety of other drivers your overwattage lights might glare? Your increasing your light output may actually be doing them harm by glaring them and temporarily blinding them. This is more dangerous when people are crossing. Pedestrians cannot see because they rely on what is available; some cars have overpowering lights. Coupled with the heavy tint you might not be able to see them quicker. Finally think about this, you cannot see others as much due to the heavy tint, plus they cannot see you due to your higher wattage bulbs.
    Don't forget to aim your lights properly too, sometimes it's just the little things.
    May 2007
    Washburn,
    Sir tanong ko lang tungkol sa hyper na osram, recommended ba na to go for a higher wattage than 80/85? or stick to etong 80/85? kc mayroon ako na hid kaso sira na and i am planning to replace it with all weather. TIA
    Josh
    Hi Guys,
    nadala ko na sa Tech ung sa Headlight ko and ang sabi nya is Ok pa naman daw ung Bulbs ko malakas pa ung buga, medyo may defect ng konti ung isa kong Headlight sa Kanan, prefer daw nya na palitan ko muna ung Buong Assembly before chaging the Bulbs,
    Btw,
    they say na mas Ok pa rin daw ung Stock na wattage ng Bulbs kesa sa Overwattage? ung sa Alternator ata ung nasabi nya dun eh... Tingin nyo, Any Comments on the side Effect of using Over wattage Bulbs, for ex. is 80++ watts?
    Jul 2006
    Read all about it www.danielsternlighting.com
    Going overwattage means you'll be taxing your alternator more than it was designed for. Upgrading the alternator, adding relays and higher gauge wiring usually helps.
    Aug 2007
    i agree with mbeige...one has to consider the safety aspects of making modifications in one's vehicle...safety to the owner of the car and safety to the people around
    Sep 2004
    Quote Originally Posted by mbeige View Post
    +1.
    People who misuse and abuse their driving lights (whether they are stock lamps, HIDs, or fog lamps) without regard for other motorists and pedestrians, I call them: Certified G.A.G.O. (Goons Aggressively Glaring Others).
    Huwag maging G.A.G.O.; use your driving lights responsibly.
Need advice on my Headlights,
