Results 1 to 4 of 4
    Dec 2004
    How do you eliminate moisture/mist inside headlights.
    still working pa naman pero basa yng casing niya.
    tanggalin mo yung rubber stopper sa likod ng headlight, tapos let the moisture dry (it will over time or kung gusto mo matanggal talaga, use your headlights para mainitan tapos matuyo. kabit mo ulit after yung rubber when it dries up.
    Sep 2004
    kung di pa din matuyo. put caulk between your lens and the plastic housing. the gap between those two are the common cause of moisture.
    pag under warranty pa po.. irereplace yan ng casa
Moisture in headlights
