Results 1 to 20 of 20
    Nag-on yung oil warning light sa panel gauge ko recently then nung pinalinis ko yung sensor sa may oil filter nawala for a week then today umilaw nanaman. I was thinking na oil sensor lang yung may prob kasi nga nung pinalinis ko nawala.
    ...But then theres the possibility na oil pump pero my car is a 2003 model mukhang hindi naman dapat right? I think kung oil pump dapat by now tinitik na ako right?
    Pakurap kurap yung ilaw...
    BTW do you guys know of a good brand of oil sensor?
    Dec 2007
    Quote Originally Posted by Djerms View Post
    did you check your Oil Level? coz if its low, then the Oil level/pressure warning light will turn on. makes sure the Oil level is full.
    aite, peace.
    Nov 2007
    yup bro check mo oil level mo saken wala akong sasakyan na 2000 up model pero di ko na expirience yung ganyan sitwsyon?
    Sep 2006
    Kung pakurap kurap, it seems loosed lang ang terminal connector ng oil sensor. If not, replaced your oil sensor, it will just cost you a few hundred bucks.
    Aug 2006
    baka mahina po yung bomba ng oil pump,check niyo po dapt pag bukas niyo ng oil cap my tatalsik na konting langis
    Oil level is at max. I replaced the oil sensor with an 80 pesos replacement part. So far so good...hindi na umilaw ulit (except during initial tuning on of key to check if everything is okay). So this means sensor na nga siguro ang may problema.
    I intend to replace the sensor nalang with original toyota sensor. Any idea how much this costs? Kung may kamahalan, ano ba ang magandang brand ng sensor? Im not that comfortable with my el cheapo sensor installed..hehe
Oil warning light
