Results 1 to 11 of 11
    Jul 2003
    may mga style taga-banawe dito e, my primary concern is what the DIY precautionary measures, etc. are, if any. then kung anong solutions/procedures needed.
    any suggestions appreciated!
    Mahirap na yatang paputiin yan kse physical flaw na. Kumbaga, kumupas na. Ang pinaka remedyo ko na lang sa ganyan is replacing it.
    may thread na yan, search mo na lang
    eto yung related thread:
    how to clean headlights (inside)??
    kung sa labas lang iyan, you can try using 3M Plastic Cleaner tapos 3M Plastic Polish...medyo mahirap na nga lang maghanap ng ganitong products :sigh:
    There was posted before a suggestion of using a glass cleaner solution and a baby bottle brush (with sponge end). Remove the housing and the bulbs. Pour the glass cleaner solution into the housing and use the bottle brush to "wipe" the stubborn dirt sticking to the inside of the housing. Then pour out the dirty solution and rinse with clean water twice or three times until no solution is left inside. To dry the housing, its suggested to use compressed air to blow out most of the water then place it under the sun to help it dry out completely.
    After cleaning it, inspect the housing for vents and holes where the dirt got in and plug it with silicon or tape it close.
    what we did with vinj's accord is tinaggal namin ung assembly..tapos nilinis namin ang loob using soap, water and cotton...kailangan mo rin ng hair drier.
    put water...with powder soap sa lens....tapos..mga 5 coton balls...play with the cotton balls inside..parang nag wi wipe sila ng dumi.....
    tapos basta para ka lang naglalaro...wiping the dirt inside...
    tapos rinse..than blow dry.
    ayun naman pala, may solusyon naman aside from full replacement...
    goodluck sa cleaning kapatid
    Jul 2003
    hehe! nice karding!
    thanks glennster, ghosthunter, i'll do that this weekend, er, tomorrow!
    astig talaga rito!
    mas magaling tlga mga pinoy kesa sa hapon! hehehehehee!
    Jul 2003
    thanks dude!
Lamps: pa'no i-restore/papuputiin?
