mga sir, bakit ganon ang mga ilaw ko, parang ang bagal sumindi. pati brake lights, parang slow motion ang pagilaw nya. mga 1.5 secs sya bago fully umilaw. help naman. kasi medyo delikado ito naka stop nako, di pa rin sya fully naka sindi. parang pakiramdam ko nagiipon pa ng kuryente:?
Baka kasi you got a battery na may factory defect sa cells sa loob. O baka naman naka Super Loud Audio Setup ka? Anyways, you could always return to where you purchased the battery to have them troubleshoot for you. Libre dapat yon. Ako kasi before nakakuha ako ng Bnew battery na nag conk out after 4 mos. Turned out that I got a defective battery. Machecheck din nila kung ang alternator mo ang nagloloko.
sir hindi malakas audio ko. probably yung contacts nga. silipin ko mamaya. after ko clean contacts, swap ko yung battery ko sa battery ng kotse ng neighbor namin. salamat!
Ano ba ride mo? Kung may kalumaan na pwede mo din consider ang wiring and alternator. Yung sasakyan ko dati ganyan din ang nangyari. Pag nag on ang A/C lahat ng accesories nag di-dim. Ang problema pala, may kalumaan na yung wiring. Pag luma na kasi ang wire, humihina na din ang conductivity nya and results to less current going to the accesories. Isa pa extra load yun sa alternator kasi kailangan nya supplyan ng extra power yung electrics mo para mapalitan yung nawalang kuryente along the wiring.
Maybe the voltage regulator turning on and off. I've seen cars do this when the battery is very low on water. Check the battery to see if it is full of water. It may say "Maintenance Free" but if the caps are removable then pop them off and look. If it is full you might go to an auto parts and have the battery tested for free. If it is good battery>>>>>>>>>>>>>>
you'rs most likely need an alternator. the regulator is inside the alt. depend on the model of your vehicle. If the charging is bad buying a new one will solve your issue with the voltage regulator. 100 percent positive on this. good luck
