Results 1 to 10 of 11
- 37
November 25th, 2002 10:31 AM #1mga sir, bakit ganon ang mga ilaw ko, parang ang bagal sumindi. pati brake lights, parang slow motion ang pagilaw nya. mga 1.5 secs sya bago fully umilaw. help naman. kasi medyo delikado ito naka stop nako, di pa rin sya fully naka sindi. parang pakiramdam ko nagiipon pa ng kuryente:?
November 25th, 2002 10:47 AM #2
baka your battery is on the way out na. Kuha ka ng tester at check mo kung it still has 12 volts.
- 37
November 25th, 2002 11:56 AM #36 months pa lan battery ko sir. at kahit umaandar alternator, ganon pa rin sya. other accesories ay ok like yung headlights at horns.
isa pa napansin ko ay parang nagdi dim ang ibang lights kapag sumindi ang iba accesories
November 25th, 2002 12:22 PM #4
check mo rin switch. baka may corrosion sa contacts. happened to me before..i just had the contacts inside replaced.
November 25th, 2002 01:19 PM #5
Baka kasi you got a battery na may factory defect sa cells sa loob. O baka naman naka Super Loud Audio Setup ka? Anyways, you could always return to where you purchased the battery to have them troubleshoot for you. Libre dapat yon. Ako kasi before nakakuha ako ng Bnew battery na nag conk out after 4 mos. Turned out that I got a defective battery. Machecheck din nila kung ang alternator mo ang nagloloko.
- 37
November 25th, 2002 02:28 PM #6sir hindi malakas audio ko. probably yung contacts nga. silipin ko mamaya. after ko clean contacts, swap ko yung battery ko sa battery ng kotse ng neighbor namin. salamat!
November 25th, 2002 03:40 PM #7
Ano ba ride mo? Kung may kalumaan na pwede mo din consider ang wiring and alternator. Yung sasakyan ko dati ganyan din ang nangyari. Pag nag on ang A/C lahat ng accesories nag di-dim. Ang problema pala, may kalumaan na yung wiring. Pag luma na kasi ang wire, humihina na din ang conductivity nya and results to less current going to the accesories. Isa pa extra load yun sa alternator kasi kailangan nya supplyan ng extra power yung electrics mo para mapalitan yung nawalang kuryente along the wiring.
BANNED BANNED BANNED
- 3,790
February 14th, 2009 09:57 PM #10
i expirience this on our headlight before, turns out its a worn out battery.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
