from the picture it looks like the angle bar is too thin, have experimented with this lamp stay before changed a lot of times to thicker angle bars, and have cut out designs. the one i have now is 1.5"x1.5" na heavy duty almost 1/4" thick.
Otep you mentioned that there are holes int he middle of your bumper sa gap, i suggest that you eliminate the angle bar and instead put the lamp tabs there bolting it sa holes (must be two for each side). use a flat bat na 1/4" thick by 2" wide. this would stop it from shaking. ma eliminate mo pa ang black angle bar that is distracting the beauty of the pajeros bumper.
question did you put the license plate together with the angle bar in one bolt? size ng bolt?
May missing piece lang to stop the shaking. Ikakabit ko when I get a hold of it.
