Results 1 to 7 of 7
May 19th, 2007 11:47 AM #1
Patanong lang ng bosing ko para sa elantra niya paano ba palilinawin yung plastic cover ng headlights medyo malabo na eh, may nabibili bang chemical para dito o palit na lang ng bago
May 19th, 2007 02:12 PM #2
If your in the south, go to camspeed (its beside st. jerome church, near alabang town center) they do cleaning of headlight housing. Parang 550pesos per housing (not so sure of the price).
- Nov 2006
- 263
May 20th, 2007 02:03 AM #3use brake fluid and alot of buffing.be carefull not to spill the fluid on your paint tho.
May 20th, 2007 06:56 AM #4
I used to remove the headlight assembly, fill it up with water, soap, and some sand and shake it...
May 20th, 2007 07:31 AM #5
A good plastic cleaner should work. I use Meguiar's PlastiX.
When you do as Heightdeprived says, make sure you completely seal it up properly after you do that, and make sure it's completely dry as well. Moisture can ruin it in the long run...
May 20th, 2007 10:17 AM #6
Ok na daw may nabili siya sa ace na glass cleaner na pang kotse nakalagay naman daw sa application pati yung sa headlights kaso ilang oras daw siya nagkayod pero luminaw din satisfied naman siya
thanks
May 21st, 2007 04:10 PM #7
papaano po yung sa mga OPTRA kung napapansin nyo po. parang natutunaw yung housing ng headlight nya. stock bulbs lang naman gamit ko.
may nabibilihan kaya nun? kasi pag sa casa ganun din ang mangyayari. tpos ang ibibigay pa yung buong assembly, wala daw silang housing lang.
Xiaomi E-Car
