How do I repair a crack on the housing of my rear break light? Is there a sealant or an adhesive glue that can be applied and hide the crack? Model: Nissan Sentra 05
You can try fixing the crack with some LOCTITE GEL superglue. The gel type super glue will help seal the crack so water will not enter. DOwnside, if you don't properly ventilate the glued area, the portion will develop a white residue (super glue). Alternative is some silicon based adhesive.
thanks for the advice
