Results 1 to 6 of 6
May 23rd, 2008 12:31 PM #1
pacensya na guys hindi ko rin kasi alam ang tawag sa light na ito, but its the light inside the car na kapag nakaopen pa yung door naka on din sya... anyway, i have my 94 toyota corolla bigbody, gusto ko sana palitan ung bulb nito, panu ba mapalitan ito? pwede ba i-diy?? salamat guys sa mga reply nyo...
May 24th, 2008 08:15 AM #2
May 24th, 2008 08:34 AM #3
madali lang tanggalin yan, naka clip lang yan.. remove the plastic cover kahit kamay na lang gamitin mo..
May 24th, 2008 10:23 AM #4
Easier said than done. Tignan mo sa gilid nung plastic housing, may slit yan on either side for a flat blade screwdriver. Remove it, and then replace the bulb. While you're at it linisin mo na rin yung lens para masmaliwanag yung ilaw. Might also want to clean the reflector. Just be careful you don't touch the bulb glass with your bare fingers, or the reflector.
Have fun!
May 24th, 2008 10:56 AM #5
Natatawa naman ako kay glenngj, definitely gagamit ka ng kamay.
* X-isle, it is called the dome lights. Just pry open the plastic housing cover on the edge with a flat screwdriver, exposing the bulb, then you can have it replaced na.
