Results 1 to 10 of 46
June 24th, 2004 05:14 PM #1
guys, pa-advise on HID xenon bulbs, i've got one mentioned in the box 560/520w H4, pede ba ito sa pajero gen1 to change the oem bulb? wala ba masusunog? mura kasi dito sa AUH.
June 24th, 2004 06:34 PM #3
560/520W?!? Meron ba ganyang kalakas na bulbs? Baka pati housing at wirings mo masunog na kung ganyan kalakas.
Afaik, HID kits or any xenon gas charged bulbs for that matter are only 35W max. Wala po itong bright or dim wattage.
June 25th, 2004 12:43 PM #4
oo nga sir ungas, nagtataka rin ako bka pang-eroplano na un..hehe, what im thinking mga fake un dami kasi klase.. what i'm using here is 100/90w(yun ang nakalagay sa box and sa side ng bulb)... thnks for the comment.
sir, wala po bang EB ang DC ngayong july, dyan kc ako for vacation.
June 25th, 2004 06:57 PM #5
Baka po over rating yung naka-sulat nun sa package. You will see the actual wattage either on the side or behind the box. Para mas sigurado, dun mismo sa bulb base nakasulat yung wattage.
DC.org EB will probably be set on the 24th of July. :D
Tsikot Member Rank 4
- Feb 2004
- 1,704
June 26th, 2004 11:59 AM #6as far as i recall, imaraming kailangang gawin to convert our heaadlights to HID. i am just not sure what has to be done.
anyone with more info on this?
i even read somewhere that in the final analysis, it might be cheaper to just get driving lights na separate instead of going with HID headlights.
i don't know if this is tue, but this is what i will be doing
June 26th, 2004 02:20 PM #7
It's not as complicated as you think. Simpleng plug and play lang ang HID kits. Usually may sariling wiring harnesses ito (based from experience sa Philips brand).
Power cords, fusible links, additional relays are attached into the package. Ang hiwalay lang yung ballast plug which is connected to HID bulb. Ang gagamitin lang sa existing headlight wiring ay yung female socket ng headlight, which is connected to the main wiring harness and box. Then you could simply control the on-off switch inside your cabin. Some kits are sold with hi-low attachments which also utilizes the same OE bright function.
Basic rule, if you know how to follow instructions, that will be an easy thing to do. Para lang kayong nagbubuo ng puzzle. All kits should come complete with instructions. :D
- Feb 2004
- 1,704
Hybrids and EV
