Page 44 of 120 FirstFirst ... 344041424344454647485494 ... LastLast
Results 861 to 880 of 2385
    #861
    Mukhang hindi yan kasya sa Sonata
    FX-R lang siguro. Or TSX. Hahaha
  2. #862
    jdjoey: sent you a PM. would like to do your Jimny
    dopa: sent you a PM
    jhnkvn: Got a new projector na pwede sa H7/H1 headlamps, ganda ng output
    Sent you a PM
    SG: abangan my new bixenon projector na better sa FX
    Sep 2011
    #863
    yes Sir got your pm. Will think about it na heheehe. How long does it takes to finish it. I believe me home service? Thanks.
    #864
    Bro masyado mo ako nililito. Hehehe
    Naghahanap na ako ng bibili ng HL ko ngayon. Pero palinis ko muna sa inyo bago ko ibigay sa bibili
    #865
    lol salpakan mo na kasi ng lexus projectors yung ...............
    celerio.
  6. #866
    Got another 2 projectors in the pipeline. Busy lang sa work but will post the output of the one for H7/H1 headlights coz my new A3.0 will not fit in those type of headlamps.
    SG: relax lang. cge bro sked mo lang. H4 ka naman so the A3.0 is perfect for you.
  7. #867
    did another a3.0 projector setup for a 2004 Strada. Also available for 2008 model-up. PM for pricing
    Output
    all pix courtesy of the client. Unfortunately all stocks of the A3.0 have been sold and 5 pairs would come around Oct 10-13. 3 are reserved already.
    Mar 2005
    #868
    Quote Originally Posted by garyq View Post
    Output
    sir anong type ng bulb / ballast nung nasa strada?
    #869
    ^ Yung A3.0 Projectors naka D2S bulbs na.
    Siguro OEM ballast na rin nakalagay
    Pero the best dyan Philips 85122+ tapos 50W ballast :evil:
    Sep 2011
    #870
    Sir Gary projector lang po ba ang may cut-off? Reflector wala? Medyo sabog talaga, kahit hindi HID?
  11. #871
    jm: philips 85122+, 50w
    SG:yep d2s yun. kung budget you can go muna with aftermarket d2s 4300k and 35w ballasts. I've got one the best quality bulb and ballasts in the market tapos eventually pag meron ng budget, you can go for Philips or the Osram CBIs tapos 50w! sweet
    harangody: meron naman cutoff kahit reflector bowl lang pero hindi kasing sharp ng projectors, pag nilagyan mo ng hid bulbs then it's worst. It seems you are starting off with this hid thing. Do it right the first time bro, imo lang para hindi sayang pera. Pag wala pa budget ipon muna para you can have the 'right' first setup.
    the new a3.0 projectors on 2010 Ford Everest
    with the new shrouds, F2
    output shots to follow, stocks available after Oct. 13. PM for pricing
    Dec 2009
    #872
    Sir Garyq, you got PM! :D
  13. #873
    dale: sent a PM also
    also had the opportunity to compare the output of my retrofit with a bolt on kit.
    the output on the left side is my retrofit and the on the right side is the bolt on kit. you can see the huge difference in intensity and the retrofit output is bleeding into the side of the bolt on kit output so in a way it is increasing the intensity of the output on the right side. This intensity on the wall will translate into actual light you will see on the road. The kit projector was the biggest in diameter and even bigger that the oem projector on the left side. This goes to show that bigger is not always better. The headlight with the bolt on kit was fogging considerably on the sides as silicon was used to re-seal the HL.
    Sep 2011
    #874
    Thanks for the reply sir Gary.
    Question lang, naka projector with HID pala low beam ng dad ko, kaso yung high beam reflector lang, so yellowish na halogen nakalagay. Ano po okay na ilagay sa high beam na kakulay ng HID para okay naman tingnan? Philips Xtreme?
    Jan 2011
    #875
    sir anu po to mas maganda kesa sa fxr na nababasa namin sa the retrofit source po? tnx
    #876
    Quote Originally Posted by blue 03 View Post
    baka RX350 ?
  17. #877
    haran: you cannot match the intensity of the hid bulb so yung color hindi rin mag match. kung gusto mo puti ng konti then go with Philips XP or Osram NB.
    blue: abangan na lang. am going to install it next week. better cutoff and spread mas consistent throughout the width.
    jun: ok naman rx350 but very pricey.
    Feb 2005
    #878
    parang negosyo naman tong thread na to, although it brings to all "retrofitted HID"
  19. #879
    Have you read all the pages? you can find many technical discussions here and some of the other new threads that just opened started out of queries posted here. Retrofit is a custom job and people need to see na possible pala yun sa oto nila before they can make the next step.
    Jul 2010
    #880
    Pls PM me the price of this hid projector retrofits for Nissan Navara. Thanks.
HID Projector Retrofits by garyq
