I'm doing a DIY project, fixing up my trunk for a simple display of the amp and sub. I'm going to get LEDs to add some life in the trunk. Where do I wire it to? Straight to the battery??? Or...to the fuses?? I'm lost..
Thanks. I was trying to do that earlier, but, I guess my dome wiring is out and not working. It's not recieving any juice. I'm going to have an electrician trace that tomorrow and get it working..I don't have a volt reader and the tools to do that. Then I'll install the LEDs myself. I was thinking of wiring it to my antenna or tail lights...but, then that would mean it would be on when the radio is on n when the car's lights are on. I only want it on when the trunk is open.
Thanks for the input! hopefully I can get this solved.
My friend installed two additional lights on my w123 trunk, sa corners nung trunk above the tail lamps. He tapped the dome light wiring, and added a switch para buksan lang kapag kailangan talaga, and I have the option to turn them on if needed. It's also completely reversible too. ;)
If you want to add life i also suggest putting simple neon lights. If you want I can send a picture of mine just give me your email. Bali yung akin, nakatap sa dating light ng trunk ko yung neons. 2 parang dirty white yung color and tago cya.
