Results 1 to 7 of 7
    Sep 2006
    Hi peeps!
    I need help on my foglamps, ayaw nya mag-on. Sabi nung mechanic baka fuse daw ang problem. Tanong ko lang kung saan located ung fuse ng foglamps and kung san nakakabili nun and kung magkano.
    Thanks for the
    Did you turn on the parklamps before testing the foglamps?
    The foglamp circuit is not energized until you turn on the parklamps or headlamps.
    Fusebox is under the dash AFAIK (ssaloon will know this). Mahal na ang Php15.00/fuse. In SM Malls they sell them by the pack (representing all possible fuse ratings).
    The fuse location depends on who installed the fog lamps. Is it OEM or aftermarket? Kung OEM it should be amongst the other fuses of your car, otherwise you'll have to look either under the dash or near the area of the batt.
    Galant SS ata ang car ni Sprex [parang kay Ssaloon?]
    Jun 2005
    Sana ang foglamps would work only if there are fogs. - Joke lang.
    Sep 2006
    Yep, 1996 Galant SS
    Sep 2006
    Hi vinj,
    OEM. near sa batt meron fuse box, kaso d ko alam kung alin dun un for foglamps..
Help : foglamps not working
