Originally Posted by mk
Of course :D Each time you turn on your headlights, you burn the filament :wink: Hindi kasama dito ang HID of course. Deterioration of Xenon gas naman yung sa kanila.
i have Philips Blue Vision installed in my headlights right now...brighter compared with stock H4 bulbs...in terms of visibily, i think Philip Crystal Vision is better...
Philips Blue Vision vs. Vision Plus thread
Not bcoz they are old styled but, sealed beams are a must when you frequently dunk your vehicle in waters above your hoodline, it wont konk out when all those h4 halogens have.
hinahanap ko yung philips blue/crystalvision and osram na brand wala talaga akong makita.. me nakita ako wurth and hella.. Okay na kaya yun... another question.. yung wattage kasi available is 130/90 do i have to change any wires sa headlights or just put on the bulb .
Originally Posted by marwen
gamit ko wurth firstec gold sa urvan ko 80/100watts... so far nakita ko difference a philips crystal vison(installed sa lancer) mas kita ang daan sa wurth gold... yellowish sya pero yung hue nya compared sa regular bulb mas maputi... great on asphalt roads.. kahit dumaan ka sa may ilaw ng hiway yung mercury bulb... makikita mo pa rin yung beam pattern mo sa road... mahal nga lang 800 isa
also what i did sa lancer pizza ko was to install relays and mas makapal na wires... then i wired it so pag na ka high beam ako pwede ko pa rin on yung low beam... kakainis kasi mga jeep at bus sa costal...
Originally Posted by impulzz
delikado yng sabay naka-on yng low beam saka high beam ng bulb. nag setup ako dati 100/80 all weather bulbs na may relay na pag nag high beam ako hindi namamatay yng low beam.
after 15 mins na takbo sa highway na naka steady yng high beam biglang pumutok yng 2 bulbs ko (sobrang init). buti na lng may foglamps ako, yun na lng naging lights ko hanggang nakakita ako ng gas station.
para safe, use the OEM wiring ng headlights, pero palitan mo na lng ng 100/80 bulbs. mahirap mawalan ng ilaw lalo na pag tumatakbo ka sa highway.
sir yan ang problem sa setup ng crosswind headlight pag di nakakabit sa pilot light dun sa dashbord yun new installed relay sabay iilaw yun low and high beam. kaya yun relay na bago installed di ko magamit kc di ko lam paano ko kakabit dun sa pilot light sa dashboard.Originally Posted by jagxtrm
Marwen,
Where did u found the 130/90 wattage bulbs, what brand and how much.
Thanks
Ive tried those sylvannia headlamps but they're not as bright as i expected. they are tough lights. I don't know where to get them here.
There is a shop near my house, magallanes, that sells round h4 headlamps that are for motorcycles. these have the same dising as the ones on new cars. they have clear lenses and the reflectors are on the cone not on the lens. so you can see clearly the inside of the headlamp. Similar to new civics. Also, they look really good and spread the light clearly.
It is also sealed very well. Ive submerged them in water and it remains dry inside.
low beam throws light well. high beam is not so good.
I think it sells for 650 a piece.
I can also get 130/90 bulbs. same shop. 150 a piece. but you'll also have to install relays. I was able to find a wiring harness that allows you to put relays neatly and it is idiot proof. unfortunately, i cant find anymore. tell me if you guys need cuz I can copy and biuld one for you. Or you could simply go to banaue but those guys do a messed up job of wiring
ive got a 2000 carnival that went from stock to phlips blue vision to raybrigs crystal something and I wasnt happy with my lights esp when it rains. I ended up doin old school methods of installing headlamp relays and 100/90 osram bulbs. much much better. than the previous bulbs.
I did a side by side comparo with the real 100/90 osram vs the philips Blue visions. installed the osram in the left side and the philips right side.
When you look at them head on you would swear the philips blue vision is as strong & Bright as the 100/90 Osrams. Look at it from the rear view mirror of a car in front of it no difference in output. You start thinking the Philips bluevision 55/60 equals 90/100 output is true. I made another test. I parked the kia 1 foot away from the garage wall and compared the beams they projected. Lo and behold. In my biased opinion, the 90/100 buld was really white with no dim spots. Light seemed to be super concentrated and was hotter to look at. The Philips blue Vision 55/60 was whiter due to its blue tint but was not as intense as the 90/100 bulb. It had dark spots with no light in its beam pattern and the light output was much weaker.
My conclusion is that the Philips bluevision bulbs seemingly brighter light is merely an optical illusion due to its blue color. Real 90/100 are the ones that give more light output.
Another hint is you might want to polish your headlamp lenses with 3m plastic polish to improve light output. Plastic headlamp with a lot of gasgas basahan need regular polishing.
my 2cents
vision plus & blue vision sa Hans Tools Shang. They also have the top of the line Diamond vision. Bot my Vision Plus for ca.1k, H4 bulbs. Tama ung claims, 30-50% more light on the road.
san ba sa manila makakabili mga sir ng philips crystal vision (5000K)? or sylvania silverstars (6500K)?? salamat
given the cost of HID systems, won't it make more sense to simply upgrade to 100 or 120 watts bulbs with relays?
If youre on a budget 100 watts or higher with relays and good wiring will do. alot better na ito sa stock. but iba talaga ang buga ng HID. hehehe yun nga lang its so damn expensive. tapos sa gabi mo lang ma appreciate.
hindi ba masyadong mainit ang 100W lamps? wala bang effect yan sa plastic housing?
Originally Posted by mazdamazda
meron. matutunaw yun. mag uupgrade ka na rin ng housing made from ceramic.
impulze san mo nabili yan? how much? pwede din sakin yan kasi sa macapagal ako dumadaan walang kailaw ilaw yung isang stretch. Kailangan pa ba ng relay?
practical talaga ang may relay a least di magiinit yung wires mo. and kapalan mo yung wires
