Results 21 to 40 of 46
    Jan 1970
    IMPULZZ,
    thx i'll try doing that
    Jan 2003
    iceman, for got to mention that the above wiring uses 2 relays, 1 for low beam and 1 for high. paano ba mag post ng pic? gawa sana ako diagram
    Jan 1970
    impulzz, ganon ba so you mean 2 relays per bulb so total of 4 relays.
    regarding diagram posting di ko rin alam eh, Mr. MOD help naman please
    If the diagram is from your hard disk and it is in gif, jpg, txt, jpeg format, you can attach it to your message using the New Reply button.
    Jan 2003
    iceman here's the diagram i made when i relayed my headlites hope this helps
    Jan 1970
    Maraming salamat ulit!
    Jan 1970
    medyo lulubusin ko na ang query ko, meron bang mas mataas na resolution nung diagram mo di ko mabasa yung mga details eh salamat in advance
    Jan 2003
    email ko na lang syo kasi di ko malakihan yung pic. di kasya sa aloted space for pics eh
    Jan 1970
    cge, sorry ha sa hassle, maganda nga sana para makita din nang iba.
    e-mail ko is jc_cabanos*ltp.com.ph
    Jan 2003
    i'll email it to you for now. di ko kasi kabisado mag attach ng pics sa tsikot eh.
    Jan 2003
    iceman sent you an email na. hope it helps also buy 4 bosch relay holders para u just plug in the relays into the holders after wiring and it also makes wring easier and avoid s loose contacts. use utilux terminals mas makapal kasi brass na gamit nila. hope my d-i-y project helps you to.
    Jan 1970
    yup, thanks a lot and imagine this costs a lot less than buying those new tech bulbs, i'm currently using the bulbs na on stock wires and sockets, so far after driving at night i always check the sockets and i can still touch them with my bare fingers di naman umiinit and with this current set-up i can see better lalo na pag umuulan. I used to have those white bulbs na 60w rating pero 100w daw output, laki talaga ng difference, lalo na ciguro when i finish this DIY upgrade
    Aug 2003
    iceman and impulz ds2 ko sana i upgrade ung bulb ng revo ko. hirap kasi mgadrive sa NLEX pag gabi pag galing me sa scul lalo n pag umuulan sa NLEX grabe hirap mga drive. puede nyo ba me tulungan about sa upgrading ng headlights ko. kung puede give me some brands ng bulbs at wttage nito tnx. give nyo naman me na shops n pudeng kong puntahan. tnx
    hope you help me guys.
    Jan 2003
    iceman, jevy.
    gamitin mo mga true rated bulds hindi yung mga bulbs claiming higher output at lower wattage inputs. osram, philips at flouser are good brands. as much as possible get the ones with the OEM color. yung mga white bulbs useless sa ulan.
    jevy, ano klase revo mo? yung maganda yung headlite assembly or yung lower model na square ang headlite assembly. sa hiace ko, square yung headlite assembly what i did was to change that sealed beam assembly to Bosch bulb type asembly laki agad ng difference.
    also try to check your headlite alinement. poor aiming of head lites results to poor visibility. kasi mali yung tinataman ng headlite beam.
    Aug 2003
    impulzz or Iceman.
    pa-email din nung diagram na mas malaki sa gen_mheloy*yahoo.com
    thanks in advance
    Jan 1970
    mheloy,
    you"ve got mail!
    Jan 2003
    mheloy,
    ano ride mo? kasi yung diagram na binigay ko kay Iceman eh pang 97 lancer(pizza) kung itlog na lancer same setup rin. di ko sure sa ibang cars kung negative switching ang head lites so better have a tester para malaman mo kung negaive switching ang headlites ng ride mo.
    Jan 2003
    Iceman,
    ok na ba yung diagram na email ko syo?
    Quote Originally Posted by impulzz View Post
    Iceman,
    bossing pa email din po ng diagram ng wiring para sa mitsubishi itlog..
    Thanks.
    Quote Originally Posted by ron318 View Post
    Thanks.
    ito pala ang email address ko arianne414*yahoo.com o kaya sa rmsanpablo*pldt.com.ph
    salamat po uli.
help - headlamp DIY upgrade
