Results 1 to 8 of 8
- Jul 2010
- 21
August 22nd, 2011 02:49 PM #1Hi tsikoteers ask lng sana ako regarding light bulbs ng fort 09 model, ano magandang brand ng bulb ilagay sa low beam projector and high beam niya and fogs din..anong magandang brand and model din..im going out of town trips every week yun maganda ang output sana for better visibilty sa road..salamat guys..=)
August 22nd, 2011 03:14 PM #2
Low Beam, if you're on projectors you can try consider HID if it works well or an all weather bulb.
High beam, try the stock wattage, higher output bulbs like Philips Xtreme Power
Fog lamps, go for All Weather.
- Jul 2010
- 21
August 22nd, 2011 03:40 PM #3*vinj- thanks, was considering hid all the way ano kaya magandang temp?for better visibilty sana..6000k?
August 22nd, 2011 06:01 PM #4
Im not too familiar with the light spectrum of HID but i'd think anything between 4K to 6K should be okay. Get too high and visibility in poor weather will get bad as the light beam will just bounce off and not be absorbed by the road surface/weather elements.
I'd go with HID only on the projectors and keep the conventional bulbs on the high beam and fog lamps to keep the beam pattern consistent. Its not all about bulb power but proper dispersion and color range of the bulbs. I'm running conventional HB4 Narva all weather low beams and HB3 Philips Vision Plus high beams on our Altis and it works well at night during my long drives up north, even in very bad weather conditions.
August 23rd, 2011 07:12 AM #5
since the low beam and high beam of the fort is separated,i would suggest you retrofit your low beam with 4800k HID projectors and maintain a halogen bulb on your high beam.if travel mainly on lighted road the fogs could be replaced with a yellow colored philips, if you travel on dark and unlighted roads you can put hid into your fogs use 4300k again for max light
- Jul 2010
- 21
August 23rd, 2011 10:45 AM #6Thanks for the reply guys..im also considering the philips xtreme vision cheaper and maganda ang performance base on my experience but my problem is baka walang available na bulb type for fortuner puro h1,h4 and h7 lang nakikita ko..meron kayang hb3 and hb4 nito?
- Mar 2010
- 301
August 27th, 2011 01:39 AM #7
- Mar 2010
- 301
August 27th, 2011 01:43 AM #8
Hybrids and EV
