Hello to all I'm new here and this is just actually my 2nd post. I also want to change my PIAA fogs I want one with beam reaching far. ano ba ma suggest ninyo ung driving or pencil light, cguro ung price range lang ng Hella. I usually travel sa provinces and nighttime ako kung bumiyahe. By the way it's for a Pajero.
sa highway and if you're a speeder maganda ang pencil kasi you'll see farther. sa slow rock crawling trails ok yon driving. of course you can have both installed and enjoy the best of both worlds. welcome to tsikot, wombat.
wombat::: Welcome aboard sir! You should see how the Lightforce RMDL240 perform! It has the adjustable wide to pencil beam just like your ordinary MagLites. Here are some comparisons based on different brands available on the market and their respective efficiency output.
Ungas,
Galing naman ng lightforce RMDL, saan ba may dealer niyan and much do you think it would cost me? I really want to replace my PIAA fogs. How about ung Hella Black magic ba yun? Ang ganda din.
why not upgrade the wattage of your fog lights muna, anyway it would be cheaper, 100 watts per foglight, big big difference compared to stock 55 watts. relays and thick wires is needed. install fuse for extra safety.
Problem with foglights, kung nasa hiway ka at higher speeds, not much use kasi wide ung bato ng light. I have two sets kasi, so I'll change one set to either driving/pencil. . Kung pwede lang upgrade ko wattage ng headlights ko kaso ma void ung warranty. Thanks for the replies
wombat::: Wala pa po tayong authorized distributor locally, but I think Freeman is willing to apply to distribute the brand here. Yung sa akin inorder ko pa sa pinakamalapit na distributor ng LightForce which is in Malaysia. I think they charged me almost 18K for a pair with airfrieght.
I've seen the Hella Blacks perform they are just the same with Hella 3000, the only difference is that the lens are black while it's not turned on. Meron din etong available na pencil and wide angle beam.
Borneo 4WD & General Trading Co.
Lot 17 & 19, Towering Industrial Center, Mile 4, Jalan Penampang
PO Box 14507, 88851 Kota Kinabalu, Sabah, Malaysia
Tel: 088-712425, 712866 Fax: 088-714880
Contact Owner: Mr. Lim Tai Yin taiyin*pc.jaring.my
