Results 1 to 16 of 16
    most of the cars meron na nito, yung kapag nakalimutan mong patayin mga ilaw tapos pinatay mo ang engine meron warning chime. yung sa patrol kasi wala nito, madalas kong naiiwan nakabukas ang headlights ko kapag day time, buti hindi pa ako namamatayan ng battery.
    paano ba maglagay nito? meron bang gumagawa nito sa mga car electronics shops?
    pati pala yung naiwan ang susi sa ignition tapos binuksan yung driver side door, wala din warning chime ang patrol. pwede din bang lagyan nito?
    Signature
    bili ka na lang bagong sasakyan. :D
    Quote Originally Posted by baiskee
    baiskee --> <-- boybi
    Signature
    Alam ko pwede ka magsalvage ng lumang 'headlamp-left-on' warning parts from old Korean vans. Parang module na kasi iyan. Yung sensor and yung chime. Kaso hindi alam exactly how it will work in a Patrol
    Oct 2003
    don't know if this DIY procedure is applicable or not, its for a honda kasi eh --> DIY headlight warning buzzer
    Dec 2003
    gs2 ko rin sana chime..sa bimmer buzzer e parang may error, parang ewan tumunog although unique haha
    Quote Originally Posted by zechs
    nice! try ko ito. salamat ng marami!
    Signature
    nice suggestion by honda peeps, very simple and easy.. ma-try nga din
    another alternaive is to get the ground wire/negative from the driver door switch with diode para pag bukas ng driver door eh dun lang tutunog, kaso kelangan tumunog lang pag naka-off na engine, perang kelangan na ng additional relays for this..
    i checked the fuses as suggested in the HCP board by using a multitester, hindi pwede para sa patrol. meron syang voltage kahit hindi nakabukas ang ilaw, pero kapag nasa ON na ang ignition, nagiging 0 volt. sayang, akala ko ok na.
    Signature
    Aug 2005
    mabuti na lang yung Xtrail ko meron nito...minsan kasi nalilimutan ko rin yung headlight na bukas.
    up ko lang, baka meron pa kayong alam na paraan.
    Signature
    Sep 2011
    Kaya ba ni Jimson toh?
    ^ Mas maganda itext mo na lang. 09395521116.
  15. #15
    madali lang toh. 2 relays na meron normally open and normally closed na contacts pwede na. sa alexan sa megamall you can get these relays, kahit yung 5A lang tapos 12v coil voltage. pag meron ako time will post the schematic
    Jan 2009
    Here's something I doodled a few minutes ago. You'll need one normally-closed relay and a 12V buzzer, among other things like wires and quick splice wiretaps.
    You'll need to tap into the Accessory (Acc) line as well as the parklights. The end result is that, whenever the lights are on (parklights or headlights), as soon as you turn the ignition key to "Lock", the buzzer will sound until the lights are turned off.
Headlight ON warning chime
