Results 1 to 15 of 15
    Oct 2007
    Is it really necessary for us to put in a relay when we upgrade our headlights to higher wattages?
    As far as I've researched, they only replace the sockets to ceramic and that's it.
    What are relays for? Is it necessary when you upgrade the wattage for the headlights? Or do you just need ceramic sockets?
    Please enligthen me. TIA
    Dec 2004
    If your upgrading from the stock 55/65 watts to 100/90 watts dapat mag relay talaga. Ma susunog yung wiring mo if wala kang relay. But you can get those 65/55 watts with output of 100watts kaya medyo mahal ng konti.
    Para sa akin mag hid ka nang alot better. Old skul na kasi yung relay at wiring harness thins sa headlights ngayon
    Oct 2007
    Quote Originally Posted by 2slow View Post
    1. HID's are kinda of expensive 8k a pop for hi/low combination
    2. Since the Vti's headlights are not designed for HID, glare would be inevitable.
    3. Pundihin ang HID pag hindi kilala yung brand.
    These are my top three reasons why i do not opt for HID. Thanks for the reply thou.
    If you'll be installing hi-wattage bulbs..
    better install thicker and hi-rated wires and relays..
    KYO H4 PLUG and PLAY Heavy Duty Headlight Upgrade Wire Harness
    http://www.eautoworks.com/html/ord-L...ss-1-33146.htm
    ARB Super Loom set
    It is supposed to give up to 25% more power to your existing headlights while using your original wiring. It simply plugs in & reduces voltage drop apparently & allows you to fit higher wattage globes.
    good reading stuff:
    http://forums.mazdaworld.org/index.p...08&#entry20308
    http://forum.205gtidrivers.com/index...howtopic=18778
    i saw 1 shop sa banawe Narva relay and wiring kit sell p700 pero di ko lang alam kung yon ung magandang klase... im still looking kung ano ung mas mganda na kit para lumakas din ung lights ng van ko... im using diamond vision ng philips, sobra hina tlga... help me what should i do to it
    Jul 2006
    Aug 2007
    try mo yung tycoon na brand, eto kasi gamit ko ngayon tingin ko lumakas pa yung buga ng ilaw ko.. meron kasi sya ballast and ceramic yung socket nya..
    Quote Originally Posted by rappiee View Post
    the greyish diamond vision philips will not work well. even with a new relay. ang hina talaga. unless your van throws light like the altis, vios or new strada.
    better replace it with vision plus.
    Quote Originally Posted by rion View Post
    what bulb should i use?same as hi, gus2 ko dn palitan na mas malakas...
    Philips vision plus or Osram Silverstar, it's a little white compared to stock.
    Philips Diamond Vision is not listed on the Philips official website because they are not legal in Europe or US.
    sir ask ko dn kung ano mgandang watts po? newbie lang din kc ako, gs2 ko tlga lumakas ilaw ko. sayang pala bili ko sa bulb na un
    Oct 2007
    Thanks for the input peeps. So it is imperative to put a relay. Are there any good brands that you can suggest? Also, cost of these relays would be greatly appreciated.
    hmm.. dag-dag ko lng a.. tnry ko mag upgrade ng relays and wirings sa banawe knin pero i failed, kc ung starex 99 model pala ay hiwalay ang low and hi nun... d ko nlng pinapalitan.. gus2 ko sana manghingi ng suggestions d2 sa forums ng tsikot, para kng ano mganda gawin, tnx...
    Aug 2004
    Quote Originally Posted by JCBalunsat View Post
    try to us bosch brand na relay.
    ito yung gamit kung relay at so far, ok naman ito.
    i think price is around 90 to 100 peso.
    I believe you can still upgrade relay kahit hiwalay. though additional cost. yung vision plus and silverstar uses stock watts 60/55. but more light throws than stock.
Headlight Relay, Ceramic Sockets, High Wattage bulbs questions.
