Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
    #21
    my guess is,
    check electrical connections, including grounds.
    Sep 2018
    #22
    Quote Originally Posted by techglimpse View Post
    mga boss possible ba macheck kung may problema un output(saksakan) ng headlight? napansin kasi sa lowbeam headlight na parang ibang un buga ng ilaw sa lowbream. pinag palit na un left at right na ilaw ganun pa din. sa passenger side un may problema. pinalitan na din brand new bulb parang mahina pa din un buga sa passenger side , sa driver side walang problema, LED KEON SONDRA gamit
    One reason for faulty low beam headlights would be problem on the blown fuse. You can check the car's manual for information about on how to access the fuses. You can also check if there are melted wires leading to any of the fuses and replaced it if necessary. Additionally, you can inspect the switch of the headlight if its functioning well. My recommendation for this is to visit your trusted auto shop to assess you properly with this concern to avoid any further problem. Hope this helps!
    May 2018
    #23
    Quote Originally Posted by beepbeepph View Post
    Already checked with Wizzard Electrical, wala naman daw problem with wirings and power output. I was just wondering what other factors can be the cause of different color output, medyo impossible naman kung sa reflector since never opened and original headlight assembly pa
    #24
    maybe the bulbs are fine.
    maybe the right headlight's throw of the beam is intentionally set differently.
    just looking at the pictures, the difference seems to be very minimal, if at all.
    if i were the howner, and everything else checks out, i'd probably let it go.
    May 2018
    #25
    sa others kasi na same model same output naman, pag malayo kasi halata na iba
    #26
    maski na switch na from driver to passenger side? di naman halata unless ill be anal about it.
    Feb 2020
    #27
    Guys pa help... yung case/bahay nung head light ng nissan gx namen sobrang blurred.
    Tingin ko need linisin from the inside. Ok naman bulb and electrical
    Any thoughts? TIA
    #28
    Quote Originally Posted by XYLHiL View Post
    Any thoughts? TIA
    the easy way out is to replace it with new.
    some say it can be cleaned. finish it off with the anti-UV protection coat, lest it re-cur. google for instructions, po.
    personally, i prefer replacement. maraming ads (carousell).
    #29
    iba parin kasi yun orig headlight bro
    Jun 2005
    #30
    Palit orig surplus
    Sent from my MI MAX 2 using Tapatalk
    #31
    Quote Originally Posted by sirkosero View Post
    Palit orig surplus
    yun orig maganda result pag ni-restore mo, unlike replacement hindi
    Jun 2005
    #32
    Same lang naman dapat yun... Original din naman yung surplus. Hanap ka lang magandang condition pa... Atleast yung mas maganda ng di hamak and condition that the existing aa cad.
    Yung taiwan like depo, mas sabog ang ilaw eh
    #33
    there are trade-offs.
    like, it takes a lot more turns to aim the replacement, but it does get aimed.
    the original may be three times more expensive than the replacement brand, but i doubt if the replacement brand will last only 1/3 as the orig.
    at ok naman ang tapon ng ilaw.
    #34
    Palit orig surplus
    Surplus Japan? RHD & LHD headlamps are designed to aim differently.
    A good preventive/solution tip is to apply headlamp protection film upon getting a brand new car or clear the blur w/ lamp polish & apply the film. Good headlamp films like LaminX can withstand the lamp heat & are self-healing.
    Jun 2005
    #35
    Yup. Syempre pang left hand drive.
    Magkaiba pricing ng rhd vs lhd surplus headlight. Bought a pair last year
    #36
    never mentioned surplus bro, replacement like made in "taiwan" and cheaper than surplus
    Jun 2005
    #37
    Ako nagsabi ng palit orig surplus. Its on my post above...
    #38
    First order of bud's just-delivered....Haze Prevention. Plotter-cut clear, self-heal headlamp film. 5min job per side.
Headlight  problem
