Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    Dec 2009
    Hi guys, i own a 2011 mitsubishi adventure. Nabulag kasi yung right side ng headlight ng advie ko. Pero pag naka bright may ilaw naman.. Sa bulb na kaya yung depekto non or sa wiring lang? Thanks!
    Sent from my LG-P920 using Tsikot Forums Mobile App mobile app
    Aug 2004
    Pundido na low beam filament mo. Replace bulbs in pairs kahit ok pa yung kabila. Use stock wattage bulbs lang. 200 lang ata isa sa Ace nyan. Dont get the fancy colored bulbs.
    Sent from my GT-N7000 using Tsikot Forums Mobile App mobile app
    Dec 2009
    Safe ba gamitin yung tig 200 sa ace hardware? Last time kasi na ngyari yan sa casa ko pa pinaayos. It cost me 2500 sa isang bulb at labor
    TY sa suggestion sir.
    i replace only the busted bulbs. no point in replacing a bulb that ain't busted. my ride's right headlight bulb got busted 5 years ago. my left headlight bulb is still original factory..
    and yes, everything is expensive in the casa... except the sales talk.
    a 20 peso bulb on the outside costs 200 kesos in the casa. but this includes installation... as if it's very difficult to reach in and turn...
  5. #5
    daan ka sa shop, bigyan kita isang piraso. H4 yan, OEM pa bigay ko syo.
    Quote Originally Posted by garyq View Post
    ako na lang ang daraan! para may spare... heh heh.
    Aug 2004
    Quote Originally Posted by radz15 View Post
    Basta Osram or Narva. Yung mga pangit ang box. Wag yung mga Circuit etc.
    Rule of thumb ko kasi yang replace in pairs. Nagsimula sa brake lights dahil laging napupundi yung isang side lang. Nung pinalitan ko sabay tumagal na. Your mileage may vary though
    Mar 2015
    I have the same problem as TS. Where can I get the headlight replacement bulb for Chevy Cruze? Nakita ko sa youtube ang bulb item number ay H13LL. Or pwede ba gumamit ng iba? Thanks
    Jun 2012
    ^Kelangang H13.
    Jul 2012
    boss yung lakiwang headlight ko may moist.. now lang ngyari to kasi nagsunod sunod ulan.. anu kya magandang gawin?
    Quote Originally Posted by nashimoto View Post
    Sa luob? Once mainitan yan ng headlight bulb sa pagsindi mo ng headlights, mangingitim na yan lens sa luob. Same with the bulb. If you know how to replace your headlight bulbs, do it and wipe it dry the bulb with a clean rag. For the inside lens, if you can reach to wipe it dry, do it too. If not, you can use a hairdryer blower just to dry the moist.
    Sent from my UP+ using Tapatalk
    May 2012
    ^ add ko lang bro, hanapin mo muna yung posibleng pinapasukan ng tubig, i-sealant mo. Kapag di mo na-seal yan, mag-mmoist ulit yan.
  13. #13
    kung nawawala naman don't worry about it
    Dec 2004
    What some people do is drop in a small silica gel desiccant pack inside their headlights (behind the reflectors so it does not interfere with the beam). Sounds fancy, but these are simply the small white packs in moisture-sensitive products (found in many products from cookies to shoes to pills) labeled "do not eat."
    A friend who had his Accord's headlights opened and cleaned experienced the same. He used the the desiccant packs from Monde's "One-One Rice Snacks" - they come with a big 2 x 2 inch pack per bag which he was able to hide behind the reflectors...and his kids enjoyed the cookies too.
    Dec 2017
    pa help naman po ako.. d p po kasi ako makapag post ng bagong thread.. yung headlight kasi ng esi ko pag bagong switch sya eh malakas naman pero pg uminit na wala na mahina na ung ilaw nya.. tsaka po pag sa hi way halos d ko maaninag yung headlight ko parang wala akong headlight.. anu po kya ang problema ng headlights ko.. yung reflector po kya nya sa loob or sa wiring lng po? need na po ba ireplace yung mismong headlight? thank you po
    Apr 2009
    Quote Originally Posted by isshin0348 View Post
    you need a grounding kit, additional headlight relay/kit (headlight brightener, probably new Headlights and a good brand headlight bulb
    Jan 2008
    Pakabit ka ng relay or palit ka ng switch stalk and fuse
    Dec 2017
    Cge sir try ko po.. pero ung sa loob ng mismong headlight parang d n xa reflective na parsng glass.. prang nag fade n or something.. isa dn ba s issue yun kung bkt d maaus headlight.. panu po malalaman f need n replace ung mismo headlight ng car? Thanks po
    Sep 2017
    Just use a simple tester to check if there is resistance and continuity para di masayang pera mo mag invest sa di kailangan if you're just using typical 55w or lower powered bulbs. But if you're using something like 90w or higher bulbs then you definitely need a relay kit for that one. Ang grounding kit madalas e di mo na kailangan kasi madalas may nakakabit na sa body ng saskayan mo to dispose the charge.
    May 2018
    mga boss possible ba macheck kung may problema un output(saksakan) ng headlight? napansin kasi sa lowbeam headlight na parang ibang un buga ng ilaw sa lowbream. pinag palit na un left at right na ilaw ganun pa din. sa passenger side un may problema. pinalitan na din brand new bulb parang mahina pa din un buga sa passenger side , sa driver side walang problema, LED KEON SONDRA gamit
Headlight  problem
